underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
Make sure the center opening will fit over the hub center. Eastwood has had those for years but more pricey I think.
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Yup, HF Chinese copy of the Eastwood tool.
Zach |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Not new but very handy.
roadster fan |
Project Frankenstein !!!!!!!! ![]() ![]() ![]() Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California ![]() |
Make sure the center opening will fit over the hub center. Eastwood has had those for years but more pricey I think. I saw that tool awhile back, and had the same concern. I guess if they have one on hand the next time I am in there I will try and measure the center, and for 4 and 5 lug. Jim |
VaccaRabite |
Baseball bats and rolling pins do the same thing. Not as elegant, I suppose, but they work.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I guess it might work, but I doubt it will be as easy as you think.
First thing you need to do is fold over the inner lip...then you can stretch the fender. Just use a hammer and dolly, that will take about ten or fifteen minutes. To stretch the fender, use a scissor jack and two pieces of wood...one on the inside and one on the outside. If all you are trying to do is roll over the fender lip on a painted car....I suspect that might do it, but I would not trust it. Rich |
VaccaRabite |
Eastwoods sells it as a fender roller, not really a stretcher. It could probably do minro stretching on the lip, but at the same dangers of using a bat. Possible cracked paint, and stretched metal pulled in from other seams. Its not a replacement for hammer and dolly.
Zach |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
These are really designed for cars with radius wheel openings.
914's aren't, which IMO is the one huge styling difference that kept them from being readily accepted as Porsches. (Just about) every other production Porsche has radius wheel openings. (928's aren't either. They had acceptance issues in the styling department too...) |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
My friend has one. He does fender rolling for cars in the area. He makes 40 bucks per fender. They turn out very nice. He offered to do the white car, I whipped out the jig saw and showed him a short cut.
But if rules only allow lip rolling then this is the hot ticket to a nice looking fender. |
toon1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 ![]() |
Hey Jeff, I will split the cost with you. I'd like to do mine just a bit before the paint goes on.
Keith |
Lo-Fi Version | Time is now: 26th June 2024 - 08:05 AM |
