76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Had a defective relay so I opened it up. Might be of interest or not.
First pic (top view) shows copper lead from #30 pin to solder terminal and just to the right of that is the attach point for the tensioning spring which keeps it in a normally open position with it's relationship to #30. ![]() Next pic shows side view of contact points. The pin on the left is #87 and the pin on the right is#87a. Notice the double contacts and that it is currently in contact with #87a. One contactor point above and one below with the plate contactor (which #30 is soldered to) in between, moving between these 2 points. I guess that would make it a double throw switch of sorts. In it's non-energized state #30 contacts #87a. When energized the electro magnet pulls the contactor plate down and away, breaking contact with#87a and connecting to #87. ![]() The 3rd pic is a side view of spring attach points and copper lead from #30 pin. Of the 3 front pins, the center pin is #30, the one to the right of it is the infamous "I ain't got no voltage here" #86 and of course the one on the left side is #86. ![]() One last thing. The #85 & #86 pin positions are flip flopped on the relay pictured on pg. 161 (in the Hayne's "Keep Trying Manual") from those pictured on pg's 147 and 154. Really? |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
I never opened one up. Nice pics... thanks.
jasons |
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None ![]() |
I made a tool out of an old relay, by jumping the pins. Its good when you want to run your fuel pump, test circuits, etc.
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
I used to work for NCR and we had a proof machine that had maybe a hundred relays similar to that for what was called relay logic. The ones we had had about 4 sets of contacts though. That relay looks to be repairable. The contacts on most relays usually have a condenser or diode somewhere in the circuit to keep the contacts from arcing when they open. If they arc they will burn eventually. Like the points in a distributor have a condenser. When you clean points if you file them usually you remove a thin gold or silver coating that keeps them from oxidizing. The least destructive thing to use is a points file which is a really smooth abrasive file or a sheet of typing paper or say some 400 grit wet or dry paper. At lot of times a relay failure is the plug in connection gets dirty or corroded or the female receptacle connections get spread out from being unplugged and replugged too much in troubleshooting.
76-914 |
Yes, it is repairable. In fact it was cleaned prior to photo's and was proven. It was rusty and not able to move when energized. I suggest that moisture was able to enter via the slots in the pins themselves coupled with a long period of non-use.
Lo-Fi Version | Time is now: 26th June 2024 - 04:37 AM |
