Fuel tank question?, Two lines on bottom right... |
jcambo7 |
Apr 3 2009, 09:34 AM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
I am trying to figure out what these two lines would go to on the bottom right of my fuel tank. I am guessing they go to tunnel lines but I am not for sure. (IMG:style_emoticons/default/confused24.gif)
This is a picture of where the lines would be at if the tank was in it's spot. I am guessing the lines go through the small hole but I don't know. (IMG:style_emoticons/default/confused24.gif) |
jcambo7 |
Apr 3 2009, 09:35 AM
I am trying to figure out what these two lines would go to on the bottom right of my fuel tank. I am guessing they go to tunnel lines but I am not for sure. (IMG:style_emoticons/default/confused24.gif) The top line has a sticker with a one n the bottom one did have one with a two which I fould underneath the gas tank. This is a picture of where the lines would be at if the tank was in it's spot. I am guessing the lines go through the small hole but I don't know. (IMG:style_emoticons/default/confused24.gif) |
xperu |
Apr 3 2009, 10:32 AM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I am trying to figure out what these two lines would go to on the bottom right of my fuel tank. I am guessing they go to tunnel lines but I am not for sure. (IMG:style_emoticons/default/confused24.gif) The top line has a sticker with a one n the bottom one did have one with a two which I fould underneath the gas tank. This is a picture of where the lines would be at if the tank was in it's spot. I am guessing the lines go through the small hole but I don't know. (IMG:style_emoticons/default/confused24.gif) Inlet and Outlet fuel lines, the larger one has a small tube like mesh filter inside the tank that should be changed, if you do intend to replace the filter (about $10-12.) then you need to replace the copper gaskets as well, I bought both at AA. You would be supprised to see the gunk in the tank where these lines enter inside the tank, try not to damage the metel tube and the fittings, they are no longer made. When I removed my lines to replace the mess filter, very little of the mesh was left. Mike |
jcambo7 |
Apr 3 2009, 10:35 AM
I am trying to figure out what these two lines would go to on the bottom right of my fuel tank. I am guessing they go to tunnel lines but I am not for sure. (IMG:style_emoticons/default/confused24.gif) The top line has a sticker with a one n the bottom one did have one with a two which I fould underneath the gas tank. This is a picture of where the lines would be at if the tank was in it's spot. I am guessing the lines go through the small hole but I don't know. (IMG:style_emoticons/default/confused24.gif) Inlet and Outlet fuel lines, the larger one has a small tube like mesh filter inside the tank that should be canged, if you do intend to replace the filter (about $10-12.) the you need to replace the copper gaskets as well, I bought both at AA. You would be supprised to see the gunk in the tank where these lines enter inside the tank, try not to damage the metel tube of the fittings, they are no longer made. When I removed my lines to replace the mess filter, very little of the mesh was left. Mike Thanks Mike. Which one is which though? |
Cap'n Krusty |
Apr 3 2009, 10:42 AM
Be VERY careful of the thick paper gaskets for the fuel fittings. They MUST be in there, and they're NLA. The Cap'n
SirAndy |
Apr 3 2009, 11:28 AM
Resident German Group: Admin Posts: 41,691 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
This is a picture of where the lines would be at if the tank was in it's spot. I am guessing the lines go through the small hole but I don't know. (IMG:style_emoticons/default/confused24.gif) No, not that small hole. You kinda have that pic backwards ... In the picture below, you can see the two fuel lines coming through the fire wall. Note the rubber grommets, those are a MUST! (IMG:style_emoticons/default/shades.gif) Andy Attached image(s) |
SirAndy |
Apr 3 2009, 11:30 AM
And the two lines are different in size, the larger being the supply line to the fuel filter and fuel pump, the smaller one being the return line.
You car won't run right if you hook them up incorrectly ... (IMG:style_emoticons/default/popcorn[1].gif) Andy |
jcambo7 |
Apr 3 2009, 11:44 AM
And the two lines are different in size, the larger being the supply line to the fuel filter and fuel pump, the smaller one being the return line. You car won't run right if you hook them up incorrectly ... (IMG:style_emoticons/default/popcorn[1].gif) Andy Thanks Andy! (IMG:style_emoticons/default/beerchug.gif) That helps out a lot. |
Cevan |
Apr 3 2009, 12:57 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
You should really buy a Haynes manual. It would answer alot of your questions.
jcambo7 |
Apr 3 2009, 02:56 PM
You should really buy a Haynes manual. It would answer alot of your questions. (IMG:style_emoticons/default/av-943.gif) I know. It acutally just came in the mail today. Bought it on wednesday n did three day shipping. Also got this one: How to rebuild your VW motor by Tom Wilson (IMG:style_emoticons/default/piratenanner.gif) So now I have reading material for when I go to Nellis AFB on the 6th thru thr 10th of this month. (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 18th June 2024 - 06:49 AM |
