Darn Cheesehead Screws, Broke another one |
DNHunt |
Feb 28 2004, 08:53 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
That stinkin little one under the head. I sprayed it with Aero-Krol waited a couple of days and tried it. No go, tried to heat it with a torch, no go. I did burn some of the old oil of the head. Bunged up the slot so I welded a tit on it and grabbed it with a vice grip. I broke the head off. Stinkin thing.
Dave |
rhodyguy |
Feb 28 2004, 08:58 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,193 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
what are you doing now dave? one thing i've noticed about aerokroil is it seems to evaporate over long periods. for the initial penetrent i use pb and then use ak when i'm ready to break some studs.
kevin |
DNHunt |
Feb 28 2004, 09:10 AM
Starting to clean up and tear down the spare engine. The final figures on the trip to JP's were 1 tank of gas, 1 1/3 quart of oil. Seems like it's using more oil all the time. Sure ran good though. Seems to me thats about 6 quarts to Frisco so, I'm getting kinda worried, I'm gonna try to ramp up the new engine. We'll see, there's lots of variables.
Dave |
rhodyguy |
Feb 28 2004, 09:20 AM
you should have had bob the steam cleaner give it the once over first. let me know if there is anything i can do for you.
your pal, kevin |
DNHunt |
Feb 28 2004, 06:43 PM
Here's the little asshole
Attached image(s) |
DNHunt |
Feb 28 2004, 06:46 PM
After several hours of messin with it. I finally got it out and the hole retapped to 5.0 X.8. I HATE CHEESHEAD SCREWS. (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif)
Dave Attached image(s) |
TheCabinetmaker |
Feb 28 2004, 06:53 PM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Why don't we replace these with hex head bolts?
Lo-Fi Version | Time is now: 26th December 2024 - 04:39 PM |
