emission failure - add cat ?, lets say ... |
jimkelly |
Apr 20 2009, 03:24 PM
you fabbed up a set of he's thru a cat and then thru a muffler.
hypothetical - if the exhaust read 700 HC & 7.00 CO - what woud it read with cat? jim Attached image(s) |
Cap'n Krusty |
Apr 20 2009, 04:25 PM
The cat is unlikely to get the CO down, but it would do a reasonably good job on the HCs. The CO you show means the car is running seriously fat, way beyond where it would be running best. If you did install a cat, with CO like that, it probably wouldn't last more than a few hundred miles anyway.
The Cap'n |
drive-ability |
Apr 20 2009, 05:31 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
Oops read the post first
I would lean out the idle system just a bit and retard the timing. That should lower the CO a bit and keep the HC from climbing. Its all a crap shot. Adding a cat would get you to pass ether way... IMO ... |
Cap'n Krusty |
Apr 20 2009, 05:38 PM
Looking at those readings I would retard the timing a bunch and you should be OK. HST, I'm assuming you didn't have the timing checked during the test , thus won't be flagged for moving it around a bit.. I had a Ca. test and repair (emission testing) license for 25 years and did see reductions in HC when installing new cats, true its not as effective but does reduce the number. I think moving the timing (ATDC) would do it.. And what's he gonna do about the CO? If he gets the CO down to below the limit for a '72, it's reasonable to assume the HCs will fall as well ................. Besides, the timing is specified, and if he doesn't fall within a degree or 2 of the specification, it's gonna fail. The Cap'n |
drive-ability |
Apr 20 2009, 05:51 PM
Looking at those readings I would retard the timing a bunch and you should be OK. HST, I'm assuming you didn't have the timing checked during the test , thus won't be flagged for moving it around a bit.. I had a Ca. test and repair (emission testing) license for 25 years and did see reductions in HC when installing new cats, true its not as effective but does reduce the number. I think moving the timing (ATDC) would do it.. And what's he gonna do about the CO? If he gets the CO down to below the limit for a '72, it's reasonable to assume the HCs will fall as well ................. Besides, the timing is specified, and if he doesn't fall within a degree or 2 of the specification, it's gonna fail. The Cap'n It all depends on the testing criteria and If he check the timing. Lots of guys say they did and don't |
orange914 |
Apr 20 2009, 05:59 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
i'd expect the high h.c.'s are high due to the high (rich) c.o. mix. lean out the mix (c.o.) as much as the h.c.'s will allow, stop at the low point before the h.c.'s go back up. h.c.'s are basically a misfire/partially burn fuel... either a lean or rich.
i've had cars fail with every component operating 100% except for a lazy cat that would not pass. a new cat does wonders. the big disclaimer here is to have everything else solid. the air cooled engines i've smogged have to be leaned down so much they sound like shit. the trick is to get the h.c. sweet spot while choking back the mix (c.o.) get that and a (good) cat (IMG:style_emoticons/default/smilie_pokal.gif) mike |
john rogers |
Apr 20 2009, 06:24 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I see you are in Milton DE, just south of where I grew up, in Milford. Left in '65 when the draft was breathing down my neck and have lived on the left coast ever since. I was back there a couple of years ago and don't remember seeing a Porsche, let alone a 914 of all things. I used to race on the dirt speedways that were abundant in the 60's like Georgetown, Little Lincoln, Delmar and several in MD that I forget.
type47 |
Apr 21 2009, 06:50 AM
This is for your V8 powered 914, right?
Antique tags? |
jimkelly |
Apr 21 2009, 09:20 AM
delaware is 1968 and older : (
looks like i need a 356 to drop a v8 into : )) i passed two years ago by just taking my air cleaner off for the test, as i had a very restrictive one on at that time. but i would also like to pollute less. subaru power would be better for the environment. -- This is for your V8 powered 914, right? Antique tags? |
Cap'n Krusty |
Apr 21 2009, 09:31 AM
Or you could just do a tuneup ............................. The Cap'n
charliew |
Apr 21 2009, 10:14 AM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
Or go to fi. even tb fi. you probably wouldn't need a cat. micro squirt tb? or move out in the country.
drive-ability |
Apr 21 2009, 10:32 AM
delaware is 1968 and older : ( looks like i need a 356 to drop a v8 into : )) i passed two years ago by just taking my air cleaner off for the test, as i had a very restrictive one on at that time. but i would also like to pollute less. subaru power would be better for the environment. -- This is for your V8 powered 914, right? Antique tags? (IMG:style_emoticons/default/flag.gif) " but i would also like to pollute less". (IMG:style_emoticons/default/flag.gif) Jim, That train left the station 30 years ago, LOL Seriously, Your close and if you can run the test without a air cleaner, well that sounds like they don't look to close at anything but what the readings. Retard the timing, tighten up the idle CO and run the idle speed as high as you can. Idle speed / circuit is the hardest area to control emissions running a carb(I'm sure someone will disagree). so raising the idle will help a bunch. I'm sure there's a limit so I would find out what it is. |
type47 |
Apr 21 2009, 11:09 AM
subaru power would be better for the environment. -- will it be ready for Hershey this weekend? (IMG:style_emoticons/default/biggrin.gif) |
Drums66 |
Apr 21 2009, 01:39 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
the air cooled engines i've smogged have to be leaned down so much they sound like shit. the trick is to get the h.c. sweet spot while choking back the mix (c.o.) get that and a (good) cat (IMG:style_emoticons/default/smilie_pokal.gif) mike [/quote] That was my experience....When I had to have smogging! retarded and leaned to shit!!...I always asked them to set it back like it was. when they passed it! relieved I don't have to do it anymore(75') (IMG:style_emoticons/default/agree.gif) |
jimkelly |
Apr 21 2009, 06:02 PM
type2man |
Apr 21 2009, 06:27 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
If you're looking to pass a smog test, disconnect one of the small vacuum lines and raise the idle and don't let it idle for more than a two minutes before doing the test, it will load up on you. If you're looking to make the emissions go down a bit, you really wont get less than perhaps 3.00 co and 300 hc for a v8. Say for example if you removed the cat from the 99 accord in your og post the readings would be around 70 for hc and .30 for the co. Newer cars with fuel injection just run better.
jcd914 |
Apr 24 2009, 12:33 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I know I am jumping in late on this but I don't get it, why can't you just lean it out?
I just had my old RV in to get smog tested and it runs way cleaner than you're showing for yours. It is a 77 motor home on a 76 Chevy 1 ton van chassis with a 350 It has no cat, no EGR. It has Air injection & EVAP The only things non-stock are the MSD ignition and a mild "RV" cam. Specs as tested a 9:35 this morning: Idle CO -- 0.65% Idle HC -- 27ppm 2500rpm CO -- 0.12 2500rpm HC -- 20 California allows 3.0% CO & 300ppm HC at idle and 3.5% CO & 350ppm HC at 2500rpm What is with your engine that you can't get it idling cleaner? Good luck Jim |
r_towle |
Apr 24 2009, 06:34 AM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Jim....alcohol...in the car, not you.
Less than a 1/4 tank of fuel...10 bottles of dry gas (alcohol) and it should pass. Go directly to a gas station and fill that tank up afterwards. Rich |
DBCooper |
Apr 24 2009, 06:58 AM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Uh oh, you just revealed The Secret. Ignore that post everybody, you didn't hear that here, it doesn't exist, and we can PROVE it!
Actually that fillup after the test is a very important part of Rich's post. Be careful about carb and other fuel parts, especially pre-e85 stuff, because that alcohol will swell some types of rubber and can really screw stuff up. No nasty gases though, just water vapor... |
r_towle |
Apr 24 2009, 08:45 AM
Yes the fill up is key...you gotta dillute it fast.
Rich |
Lo-Fi Version | Time is now: 26th June 2024 - 06:59 AM |
