> troubleshooting, brake lights on all the time..
7391420
post Mar 1 2004, 12:24 PM
After replacing the Master Cylinder, and putting everything back together I just noticed that my brake lights are on all the time... when I put in the new M/C I noticed that the electrical sensor was different on the new one so I unscrewed the old one, pulled off the new one from the new M/C and screwed the old sensor onto the new M/c....sounds like it's grounded?
can I just un-plug this sensor? or will the brake lights then not work? or will I get a warning light on the dash...
help!
-Adam
Replies(1 - 7)
ArtechnikA
post Mar 1 2004, 12:29 PM
rich herzog
if the /4 is like the 911 and 914.6, the brake lights are turned -off- by the lever microswitch in the pedal box. if the lever is on the wrong side of the actuator disk, the lights will stay on. it has nothing to do with the MC.
that's IF it's the same, which i donno. but it's an easy thing to check ...
Dave_Darling
post Mar 1 2004, 12:44 PM
914 Idiot
It is--this is exactly what happens. The arm for the brake light switch goes onto the other side of the metal disk on the brake pushrod. Check Haynes for photos, you can just see the position of the arm.
--DD
post Mar 1 2004, 01:03 PM
Thanks guys,
I'll look at it in a few minutes, sounds like when I pulled out the old MC- the lever probably flipped over to the other side?
please tell me I dont need to take the M/C out to flip it back over....
-Adam
ArtechnikA
post Mar 1 2004, 01:11 PM
rich herzog
QUOTE(7391420 @ Mar 1 2004, 11:03 AM)
nah. pull the carpet, pull the pedal board, and 5 minutes with a straight-blade screwdriver to loosen the microswitch and reset the lever - tops.
post Mar 1 2004, 01:15 PM
thats what I was hoping to hear! thanks again.
-Adam
post Mar 1 2004, 07:55 PM
as usuall you guys were right on, took five minutes and all is well again. Thanks!
BTW, it did seem as if the lever was right on the edge of the washer where it sits so I bent it inward just a bit and now it seems more secure. I am thinking that maybe driving with the lever flipped downward pushed it in a bit, anyway it works perfectly now
ArtechnikA
post Mar 1 2004, 07:58 PM
rich herzog
QUOTE(7391420 @ Mar 1 2004, 05:55 PM)
the power of BTDT...
yr welcome !
- Lo-Fi Version Time is now: 4th January 2025 - 08:00 PM
