Brian Mifsud |
Mechanical Engineer ![]() ![]() ![]() Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None ![]() |
I've been offline a long time, but I know there are knowledgeable machinists in the forum.
I have several 316 Stainless Steel castings where the hole for the shaft needs to be very accurately located on the centerline to prevent imbalance. This is an impeller that spins at 1200 RPM. The shaft hole has been bored on a lathe to .4981". The nominal hole size is supposed to be .4987 +/- .00025". The shaft which is supposed to insert into this hole is .4985". I have a .4990" cobalt tipped, straight flute reamer. Question: If I don't get the reamer to bore position dead co-axial, will the reamer change the hole POSITION? HOLE SIZE: I understand that the reamer is built to -.0000 +.0002", so in theory, I'd be taking up to .4990 + .0002 = .4992 Reamer Size .4992 -.4895 = .0007" clearance on the shaft to hole. But in removing that material, will the reamer follow the path of least resistance and stay dead co-axial to the bore location? Any variance off the impeller center axis cauese imbalance. Thanks Brian |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
hone em.
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
A reamer will folow the parent hole.....if it's properly tapered.
Honing allows you to "creep up" on the required size....but you're gonna be there a while. |
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
I agree with the hone. You only need to hone 6 tenths of a thousandth to hit nominal, and the hone will keep the bore centered in the correct location.
Millerwelds |
Pleepleus ![]() ![]() ![]() Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California ![]() |
Well, when I am reaming the hole I like to....... (IMG:style_emoticons/default/bananabang.gif)
BMXerror |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 ![]() |
Either way will work, but I see no reason the reamer won't work. The reamer will follow as long as you don't dwell it in the hole or drastically cock it away from centerline. Just line it up the best you can (test indicator would be the most accurate), plunge it in at a quick, but steady rate, and retract at the same rate. This ought to give you the results you're looking for.
Mark D. |
Lo-Fi Version | Time is now: 25th June 2024 - 06:30 PM |
