VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
I am taking my header to the ceramic coater on Friday. I need to get new gaskets for re-installation but they are not a standard size that I can find in a FLAPS.
So, anyone know what size they are, or where I can order them from? Zach |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
well,
The stub pipe gaskets...maybe Foley. The big flange...go to Midas or Mieneke muffler...they have almost every shape you can imagine in stock...up on a huge rack. Rich |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Eurorace? The Cap'n
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
hows the motor coming along? you found the oil pressure issue?
westdesert |
Newbie ![]() Group: Members Posts: 29 Joined: 27-September 08 From: Utah Member No.: 9,592 Region Association: None ![]() |
I am taking my header to the ceramic coater on Friday. I need to get new gaskets for re-installation but they are not a standard size that I can find in a FLAPS. So, anyone know what size they are, or where I can order them from? Zach Zach what does it cost to coat w/ceramic and what is the benefit Kelly |
VaccaRabite |
Westdesert,
ceramic coating provides protection from rust that won't flake off from heat IF (big if) it is applied correctly. It also insulates the header pipes so that they do not melt your clutch and speedo cable. I am doing it for the heat protection, as the Eurorace header is known for melting cables. If it is done incorrectly, though, it is ~200 wasted dollars, as it will start to flake off quickly. Zach |
VaccaRabite |
Cap'n Krusty |
Eurorace? The Cap'n I can't find a web site for them. Or a phone number. Hence, my question. Zach I'm pretty sure I wouldn't spend a bunch of money on a product with no product support ........................ Be that as it may, the earlier suggestion that you go to a good muffler shop and match something up is a good one .............. The Cap'n |
Lo-Fi Version | Time is now: 24th June 2024 - 11:39 PM |
