> Back Pad mounting, early '70 six
djm914-6
post May 30 2009, 11:35 AM
Happiness is: Getting on the road
Can someone tell me what screws or bolts are used to mount the back pad to the firewall? I know it was mounted at some point but for the life of me I don't seem to have anything that fits anymore.
I assume these are to be machine screws as it looks like there is a nut behind the tin?? What size and shape do I need to buy?
Thanks.
Oh, there is a larger green and (IIRC) brown wire with female terminals in the tunnel by the interior light wires. Any idea what those are for?
Replies(1 - 2)
914Sixer
post May 31 2009, 06:55 AM
Wires are for the heated back window. They were built into the harness on the -6 but not on the -4. I will have to check the chrome phillips metal screw size.
djm914-6
post May 31 2009, 11:59 AM
Thanks for the info. Let me know if you find that screw size so I can pick up a set. I figure I should be able to get something at Lowes if all else fails.
- Lo-Fi Version Time is now: 4th January 2025 - 09:37 PM
