> Front Sway Bar Mounting Plate
jd74914
post Jun 4 2009, 11:36 AM
Its alive
I have to pull my tank out to replace some lines and other stuff so now seems like the perfect time to put in a sway bar. I'd rather fab the plate than buy it (college student budget), and remember seeing a .dwg or picture with its dimensions. Does anyone have a copy of those or know the dimensions? The only one I'm really concerned about is the bolt spacing.
Thanks. (IMG:style_emoticons/default/smile.gif)
Replies(1 - 5)
SLITS
post Jun 4 2009, 11:46 AM
"This Utah shit is HARSH!"
Bird Board has a template for drilling the holes that is printable off their site.
jd74914
post Jun 4 2009, 11:52 AM
Its alive
Cool. That's easy. Thanks.
Anyone know the bolt size?
Edit:That should be on PET so its attainable, NM.
McMark
post Jun 4 2009, 01:23 PM
914 Freak!
Whatever bolt you want. But please, stick with metric/original and use 8mm x 1.25 bolts. (IMG:style_emoticons/default/wink.gif)
914werke
post Jun 5 2009, 10:07 AM
BTW the Factory didnt put anything inside to accomodate the anti-sway bar they spot welded a nut plate on the outside.
post Jun 5 2009, 11:19 AM
Resident German
QUOTE(rdauenhauer @ Jun 5 2009, 08:07 AM) *
BTW the Factory didnt put anything inside to accomodate the anti-sway bar they spot welded a nut plat on the outside.
The factory also ran a skinny ass sway bar that didn't put much stress on the surrounding sheet metal.
If you think you might decided to upgrade your sway bar in the future, do yourself a favor and weld in a backing plate ...
(IMG:style_emoticons/default/stirthepot.gif) Andy
- Lo-Fi Version Time is now: 26th December 2024 - 11:07 AM
