Dusty Plenum, Worth to clean? |
kkid |
Jun 16 2009, 02:30 PM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
How did you guys clean the plenum?
I got a free one @ swap meet. It has dust and shows some rust but only surface. Since I see no crack I plan to replace with the one on the car someday. Any suggestions will be appreciated. (IMG:style_emoticons/default/cheer.gif) |
SLITS |
Jun 16 2009, 02:33 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Hot water and soap .......
or Carb cleaner and then repaint or Parts washer if you have access to one or Hot tank at a machine shop or Why clean it? |
kkid |
Jun 16 2009, 03:11 PM
Sorry, I should have emphasized that it has some rust inside and out.
How about blasting? I wanna clean it because it wouldn't be cleaned another 35 years if it missed this chance. Thanks! |
McMark |
Jun 16 2009, 03:59 PM
I would get it blasted or soak it in a water/muriatic acid bath (CAREFUL!). I've seen them rust all the way through and then you have problems that will be hard to trace.
BarberDave |
Jun 16 2009, 06:36 PM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
If you remove all the rust ,it no longer with be worthy of the name ( 914) it will morf in to a Olds. or Buick Dynaflow. As in it said ,so shall it be Dave |
SirAndy |
Jun 16 2009, 06:57 PM
Resident German Group: Admin Posts: 41,806 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Soda blast ...
Then check for cracks, especially around the through holes. That's one hard to find air leak ... (IMG:style_emoticons/default/shades.gif) Andy |
championgt1 |
Jun 16 2009, 07:23 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/agree.gif) Damn near tore my entire system apart looking for a vacuum leak and a crack in the through hole was the culprit.
Lo-Fi Version | Time is now: 21st September 2024 - 06:58 PM |
