OG Gas Tank Return Line Question, Can the return be used to supply fuel to a pump? |
wallys914 |
Jul 7 2009, 11:02 PM
In life you don't get what you want, you get what you negoia Group: Members Posts: 190 Joined: 10-October 08 From: Garden Grove, Member No.: 9,631 Region Association: Southern California |
I am looking to add a Nitrious system on my car but figuring out the fuel deliver to the extra pump would be difficult I thought, then I started thinking if the return line could be used to supply fuel to the Nitrious fuel pump that would resolve that issue...
Any one know? |
Dave_Darling |
Jul 8 2009, 12:37 AM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I think it will--up to a point. There is no strainer over the return port, and I believe that the end of the return fitting inside the tank is higher than that of the supply fitting. So it will run out of gas earlier.
I don't know of any check-valve in there or anything like that, though. --DD |
SLITS |
Jul 8 2009, 11:06 AM
The return fitting is concially shaped on the end with a hole of about 1/8" from memory. You would severly restrict the fuel flow to a pump by using this fitting. I've seen cars with the suction and supply reversed where they wouldn't run above about 3K ... they would stumble and miss due to lack of fuel.
pktzygt |
Jul 8 2009, 11:55 AM
Member Group: Members Posts: 328 Joined: 20-March 07 From: Chesapeake, VA Member No.: 7,611 Region Association: MidAtlantic Region |
Tangerine sells larger than stock stainless lines. Mine will go in this weekend, time permitting.
McMark |
Jul 8 2009, 12:21 PM
The supply line has a strainer inside the tank and protrudes upward, both to minimize the particulate that enters the line. The return line has neither and is therefor more prone to ingesting particulate from the tank.
wallys914 |
Jul 8 2009, 02:43 PM
Thanks Mark, (IMG:style_emoticons/default/type.gif) that handles the particulates of this question... (IMG:style_emoticons/default/av-943.gif) I will have to try it then.
Another question, has anyone fab'd up an AN fitting for a 914 tank? |
Lo-Fi Version | Time is now: 25th June 2024 - 07:47 PM |
