How do you use an End Play tool |
VaccaRabite |
Jul 11 2009, 07:33 AM
En Garde! Group: Admin Posts: 13,616 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I got an end play tool, and I can't figure out how it works.
It clearly bolts to the flange, I am guessing over the flywheel. But how do you use it to measure flywheel endplay? It just came with the tool, no instructions. Zach |
VaccaRabite |
Jul 11 2009, 07:34 AM
One of these tools:
(IMG:http://www.chircoestore.com/catalog/images/012107.jpg) |
jimkelly |
Jul 11 2009, 07:47 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i think you put a guage on it and mount it to the block - with the guage touching the end of the crank. to measure the play in the crank with flywheel not yet installed? by tapping lightly on the ends on the crank - in order to determine if you have enough shims in there?? maybe with yours you just use a feeler guage or mic to measure gap??
qa1142 |
Jul 11 2009, 07:55 AM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
tap flywheel towards the tool.
set the bold to just touch flywheel. Tap play the other direction and measure the gap with feeler gauges |
URY914 |
Jul 11 2009, 11:32 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 124,254 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
endplaytool.com
VaccaRabite |
Jul 11 2009, 12:58 PM
ME733 |
Jul 11 2009, 01:25 PM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) Its the feeler guage type of end play tool. (IMG:style_emoticons/default/bye1.gif)
charliew |
Jul 11 2009, 04:41 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
It's for guys that only use feeler gauges. If you can get a dial indicator mounted it is really easier to use. The feeler gauge is as most know a matter of feel and tight to one is not tight to another and if any lubricant is involved is really a relative thing sorta like another thing about tight or loose and the amount of lubrication needed. Course the tighter it is the harder it is to get it in, er the gauge.
aircooledtechguy |
Jul 12 2009, 01:22 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
Actually the new end-play tools like the one pictured have a 1.0mm thread pitch on the screw, so each 1/4 turn is .25mm. No feeler gauges needed.
I've never trusted that though. I use a dial indicator exclusively on my motor builds. |
Lo-Fi Version | Time is now: 26th December 2024 - 07:19 PM |
