malaga_red75 |
'74 2.5L N/A Subie ![]() ![]() Group: Members Posts: 454 Joined: 5-March 06 From: Menlo Park, CA Member No.: 5,674 Region Association: None ![]() |
So I am using aftermarket relays for the fuel pump and the cooling fans on my subaru conversion, using the stock ECU. I have attached a picture of the relay diagram.
![]() So, there are two circuits, an 'inner' circuit and an 'outer' circuit. The outer circuit is only completed when the inner circuit's electromagnet is active. It is currently wired like this: The 'inner circuit' receives a signal from the fuel pump pin on the ECU which goes into terminal 86 on the relay. (and here is where i think it has been wired wrong), coming out of terminal 85 the wire goes into the ECU into a 12 volt power connection. This is for the 'inner' circuit which should ignite the electromagnet. --- I THINK THIS IS WRONG. ---Shouldn't the wire coming out of terminal 85 go to a ground? thus completing the inner circuit and cause the magnet to attract the arm to complete the 'outer' circuit. I hope that wasn't too confusing, let me know. Thanks a bunch! -Peter |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
So I am using aftermarket relays for the fuel pump and the cooling fans on my subaru conversion, using the stock ECU. I have attached a picture of the relay diagram. ![]() So, there are two circuits, an 'inner' circuit and an 'outer' circuit. The outer circuit is only completed when the inner circuit's electromagnet is active. It is currently wired like this: The 'inner circuit' receives a signal from the fuel pump pin on the ECU which goes into terminal 86 on the relay. (and here is where i think it has been wired wrong), coming out of terminal 85 the wire goes into the ECU into a 12 volt power connection. This is for the 'inner' circuit which should ignite the electromagnet. --- I THINK THIS IS WRONG. ---Shouldn't the wire coming out of terminal 85 go to a ground? thus completing the inner circuit and cause the magnet to attract the arm to complete the 'outer' circuit. I hope that wasn't too confusing, let me know. Thanks a bunch! -Peter Not cornfusing. The ECU fuel pump output is a switched ground. So your set up sounds correct. |
malaga_red75 |
Ok, so that leads to my next question, what would cause the fuel pump output signal not to switch?
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
try reversing the way you have it wired to the relay..one side may be ground.
RIch |
budman5201 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 ![]() |
jt914-6 |
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States ![]() |
Maybe this will help......
r_towle |
so you wired it backwards.
85 is ground...not positive Rich |
busmech |
Member ![]() ![]() Group: Members Posts: 68 Joined: 12-April 09 From: Daly City Ca Member No.: 10,258 Region Association: Northern California ![]() |
85 and 86 does not matter which one is pos. and which is neg.
Most ecu circuits are outputing a ground to activate a relay, but some are bat. voltage. You need to find out what you have, conect it to 85 or 86 does not matter, and then the other one goes to a ground or batttery. you should have 30 wired to battery, fuse protected of course, then 87 goes to the fuse pump |
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
busmech |
Here is a good explanation of the bosh relays
http://www.bcae1.com/relays.htm |
busmech |
Just above the animation there is a paragraph that says what i am saying.
I work on buses with relay logic that controls a lot of the functions, bosch style to 4 pole relays, time delay relays etc. |
busmech |
The only time that you need to have a certain polarity is when you use a supression diode, which the questioned relay does not have.
malaga_red75 |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
Busmech, you are correct. Unless the relay has a protection diode to discharge the build up of voltage when the field collapses, then is does not matter which contact is + or ground for the coil circuit. It is just an electromagnet.
Tom |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
85 and 86 does not matter which one is pos. and which is neg. ... Yes it matters, if you wire it opposite you will get the field reversed which will keep the output from changing ever. Generally speaking, you're wrong. The relay doesn't care about the polarity of 85 and 86. I'm sure there are diode protected ones out there, but I've yet to run across one. The Cap'n |
mskala |
85 and 86 does not matter which one is pos. and which is neg. ... Yes it matters, if you wire it opposite you will get the field reversed which will keep the output from changing ever. Generally speaking, you're wrong. The relay doesn't care about the polarity of 85 and 86. I'm sure there are diode protected ones out there, but I've yet to run across one. The Cap'n yes, since arm is not a magnet but just steel, I see it would not matter. |
rascobo |
Member ![]() ![]() Group: Members Posts: 203 Joined: 26-July 07 From: Portland,OR. Member No.: 7,948 Region Association: Pacific Northwest ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 11:10 PM |
