orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
does anyone have the wiring diag. for wiring up a (3 wire?) stewart/warner voltage gauge?? ALSO it'd be great to know if there are any o.e. wire harness wires i can hijack into if need be.
thanks, (IMG:style_emoticons/default/beerchug.gif) mike |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Don't have one, but the wires should be +12 volts, ground, and illumination. You can figure that the ground wire will be zero resistance to the gauge body, and the illumination will light up the guage, so the only connector left will be the +12 volt.
I would hook up the illumination wire to one of the current guage lights, so it will dim along with the others. The ground can go to any good ground point, and the 12 volt should be connected to any switched hot on the fuse panel. |
orange914 |
Don't have one, but the wires should be +12 volts, ground, and illumination. You can figure that the ground wire will be zero resistance to the gauge body, and the illumination will light up the guage, so the only connector left will be the +12 volt. I would hook up the illumination wire to one of the current guage lights, so it will dim along with the others. The ground can go to any good ground point, and the 12 volt should be connected to any switched hot on the fuse panel. the strange thing is there are 3 isolated (not grounded to body) wire hook ups that go thru the casing to the gauge(plus the bulb with it'short power lead), thats what gets me... one is marked "S", one marked "I" and one not marked. i'm wondering if maybe: 1] the "S" is stator hook up (hot when running, like hooking a choke pull off to be hot only when running). 2] the "I" on the alternator i think is always hot... "I" to that??? 3] unmarked to ground? any thoughts, maybe someone has a new s/w gauge w/ included wiring directions (IMG:style_emoticons/default/poke.gif) thanks |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Friends don't let friends use SW gauges...........
The Cap'n |
neil30076 |
Recovering dismantler! ![]() ![]() Group: Members Posts: 397 Joined: 12-September 06 From: San Diego ( RB) CA Member No.: 6,826 Region Association: Southwest Region ![]() |
does anyone have the wiring diag. for wiring up a (3 wire?) stewart/warner voltage gauge?? ALSO it'd be great to know if there are any o.e. wire harness wires i can hijack into if need be. thanks, (IMG:style_emoticons/default/beerchug.gif) mike Google is your friend - http://www.stewartwarner.com/Tech/tech1.html (IMG:style_emoticons/default/biggrin.gif) |
orange914 |
does anyone have the wiring diag. for wiring up a (3 wire?) stewart/warner voltage gauge?? ALSO it'd be great to know if there are any o.e. wire harness wires i can hijack into if need be. thanks, (IMG:style_emoticons/default/beerchug.gif) mike Google is your friend - http://www.stewartwarner.com/Tech/tech1.html (IMG:style_emoticons/default/biggrin.gif) yeah, thanks, i googled them a few days ago and it seems the only way i can get the the wiring is in the gauge catalog. got one coming. i was looking on e-bay and relized that there must be 10 ameters to 1 volt gauge. that made me really think that maybe a ammeter would be better anyway (IMG:style_emoticons/default/dry.gif) |
neil30076 |
If you have the part number try calling summit racing - they sell them and their tech support is usually very good -
Cap'n Krusty |
If you run an ammeter, you have to install it inline, meaning you have to have a largish quantity of big honkin' wire and find a place to run it .............
The Cap'n |
orange914 |
If you run an ammeter, you have to install it inline, meaning you have to have a largish quantity of big honkin' wire and find a place to run it ............. The Cap'n your right, maybe that'l keep the volt in there. now i'm thinking about years ago on one of my first cars... i probably ran 10 gauge wire on an ammeter, holy shit. how did i ever keep power to to rest of the car without it being a fuseable link mike |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Ammeters suck....I gave mine the float test. It failed. I think it's less rusty now at the bottom of the Pacific....
Lo-Fi Version | Time is now: 1st July 2024 - 07:13 AM |
