VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,479 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Engine is in. Everything is ready.
But I don't get any spark. Coil seems to be okay. I need to know if there is anyway to test the mallory? I am not getting any power to the plugs. I have tried putting a timing light on the plug wires and putting the timing light on the wire from the coil to the mallory just to see if there is currant, which there is not... I am getting power to the coil. I am SO CLOSE!!!! I just need to get this bitch running. Zach |
VaccaRabite |
Also, the unit worked when I pulled the engine out last month.
In the good news side of things, I am getting enough oil pressure to turn off the light just running the starter. Zach |
Kirmizi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None ![]() |
Zach,
I just pulled out the installation instructions and there's not much there. Have you double-checked all your wiring/connections/etc...? It states, "If the engine fails to start, rotate the distributor in small increments clockwise or counterclockwise until the engine starts. Do not exceed more than ten degrees ... in either direction." Mike |
VaccaRabite |
Zach, I just pulled out the installation instructions and there's not much there. Have you double-checked all your wiring/connections/etc...? It states, "If the engine fails to start, rotate the distributor in small increments clockwise or counterclockwise until the engine starts. Do not exceed more than ten degrees ... in either direction." Mike Saw that. Even if my timing was off, I'd be getting a pulse through the plug wires. I'm not getting any pulse. Mike (DrEvil) and I triple checked the wires. Its is in properly. Zach |
brilliantrot |
Member ![]() ![]() Group: Members Posts: 125 Joined: 27-April 07 From: Costa Mesa Ca. Member No.: 7,699 ![]() |
I fried the electric portion of a mallory when my codriver left the key on for 6 or 8 minutes so they do go bad.
VaccaRabite |
I have ordered a new optical sensor from CFR. I'll see if that helps things. I really want to get this car moving again. It is so close I can taste it.
Zach |
yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
brilliantrot |
Chris is good with shipping things fast as I had him send me a spare but now that I need it I can't find it. Anyways, see if you can find a stock one or even the dreaded 009. Mine failed right before timed runs at an autocross. 10 min later the 009 was in with a compufire module in it and I was away again.
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,003 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
From Yeahmaq's link, "you will need a ballast resistor installed in the system to prevent killing a good module (if you attempt to start the engine). "
A yup, ya done kilt it with that misplaced wire (IMG:style_emoticons/default/wink.gif) |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,339 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I didn't use a ballast resistor, but used a Bosch Blue coil. Seems like this combo works. I'm notclear when a ballast resistor is required??
From Yeahmaq's link, "you will need a ballast resistor installed in the system to prevent killing a good module (if you attempt to start the engine). " A yup, ya done kilt it with that misplaced wire (IMG:style_emoticons/default/wink.gif) |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Most Bosch blue coils have the required resistance so a ballast resistor isn't necessary.
A weakness of the Mallory optical unit is that stray voltage signals can kill them. If you don't have spiral wound plug wires that can do it when the engine is shut down. |
VaccaRabite |
I seem to remember a chart that said what bosche blue coils had the internal ballast resistors, and which did not.
My car is using the blue coil, but also used a resistor, so I am guessing that my coil needed the resistor. How do I know for sure? Zach |
ChrisFoley |
IIRC a coil that measures more than 1.4 ohms on the primary winding (plus and minus terminals) has the necessary internal resistance.
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
Dr Evil |
Your coil was 5.1K both terminals to center and 0 ohms between the +/- so you needed the resistor that was not in the circuit.
VaccaRabite |
Your coil was 5.1K both terminals to center and 0 ohms between the +/- so you needed the resistor that was not in the circuit. *nods* *smiles* *hopes no one notices I have no idea what Evil is saying...* I have a conceptual idea of what is going on, but I would not be able to explain it if asked, or properly replicate the experiment... Zach |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Some coils have built in or internal ballast resistors. They measure higher resistance (3-4 ohms or so). Yours reads 0 ohms, so it's not internally ballasted.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
And internal ballast creates resistance.
Its also called a resistor. This resistance needs to be in the system in order for your electronic sensor to function. You have two choices. 1 is buy the correct resistor and put it inline like the manual says...or you could just hand it to Dr Evil and have him wire it up. 2, you could buy a different coil that has the built in resistance you need....but the risk of that is you WILL forget when the coil gets replaced down the road... Rich |
VaccaRabite |
I have the resistor already. I was trying to determine if I was using a resistor when I did not need one, as Chris had said many of the blue coils have internal resistors. it turns out that mine does not. So, using the resistor I have is the right thing to be dong.
Zach |
stepuptotheMike |
medium pimpin ![]() ![]() ![]() Group: Members Posts: 565 Joined: 4-September 06 From: Charlotte, NC Member No.: 6,769 Region Association: South East States ![]() |
I went the extra step and added Mallory's line filter. I think it was like another $26 bucks. Figured that was cheap insurance against nuking a module. So I've got the ballast resistor, the line filter and the mallory (IMG:style_emoticons/default/biggrin.gif)
But what if I get struck by lightning????? (IMG:style_emoticons/default/biggrin.gif) Mike |
Lo-Fi Version | Time is now: 28th June 2024 - 06:29 PM |
