Rod |
Senior Member ![]() ![]() ![]() Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England ![]() |
I want to fit a header on my 914, and am looking into heating options. I could fit a tangerine heat exchanger or alternatively fit an eberspacher heater in the front. I would remove all the the piping in the cabin, install the heater in the front. The unit has an internal fan, so the original blower could be removed and the gas heater be installed in it's place, with the output pipes going to the air controllers on either side. The dash controls would then direct the hot air either up or down, and I'm sure the fan controller on the dash wiring could be modified to turn the heater on and off.
I'm not concerned about having cold air blown through the vents - if I want fresh air I open the window! So does anyone know what the airflow is like out of the eberspacher? Would I need a seperate fan to increase airflow sufficiently? Has anyone installed one in a 914 before?? |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
If you search back, there is a site that shows an Eberspacher gas fired heataer in a 914 front trunk. I don't know of anyone that's actually seen a real installation, but they do seem to work pretty well in VWs and early 911s.
I also investigated doing this in my 914-6 conversion, but finally decided on putting on some heat exchangers instead of the headers I had. I did purchase a used heater, and it does put out a fair amount of heat, so I think it would work. My idea was to perhaps mount it somewhere back by the engine area, and them just use the factory heat/ventilation controls to keep things simple. Good luck with your project, please post some pics of your install if you do it! |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
No one has done it that I've seen.
But a lot of people have talked about it (myself included). |
aircooledtechguy |
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest ![]() |
A BN2 from a Beetle or type3 would be a nice addition in a 914. The flow is sufficient to heat a type-3 Squareback in winter no problem. The only issue I see is what to do about fogging the front windows. . . Without the heat blowing on the windshield, they will fog badly.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
go search on thesamba or maybe on ebay for a user called "heaterman"
He is THE guy for these units...he rebuilds them and sells all the parts. He will be able to advise you on the cost. A friend of mine has one in his vw thing...he loves it. It has a remote start so he can get the car all heated up before he even gets in the cab...now that is cool. SirAndy has a great picture of the installed unit that was available as an option back in the day for the 914... Rich |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
I've got a really cherry Webasto unit with the extra fuel pump, but that's as far as I've got.
IMHO it would be pointless to put one of these in a car without including defrost. |
Rod |
A BN2 from a Beetle or type3 would be a nice addition in a 914. The flow is sufficient to heat a type-3 Squareback in winter no problem. The only issue I see is what to do about fogging the front windows. . . Without the heat blowing on the windshield, they will fog badly. Having it plumbed into the two air boxes on the bulkhead would enable you to either have the air up onto the screen or down to the footwell, so no probs with screen demsting... go search on thesamba or maybe on ebay for a user called "heaterman" He is THE guy for these units...he rebuilds them and sells all the parts. He will be able to advise you on the cost. Rich I have tried but the website is down, I'll have a more comprehensive search later. - I'm off to a 914 meet in 10 minutes (IMG:style_emoticons/default/smile.gif) SirAndy has a great picture of the installed unit that was available as an option back in the day for the 914... Rich I never realised they were a factory option on a 914....... Sirandy, please post that pic (IMG:style_emoticons/default/pray.gif) |
r_towle |
A BN2 from a Beetle or type3 would be a nice addition in a 914. The flow is sufficient to heat a type-3 Squareback in winter no problem. The only issue I see is what to do about fogging the front windows. . . Without the heat blowing on the windshield, they will fog badly. Having it plumbed into the two air boxes on the bulkhead would enable you to either have the air up onto the screen or down to the footwell, so no probs with screen demsting... go search on thesamba or maybe on ebay for a user called "heaterman" He is THE guy for these units...he rebuilds them and sells all the parts. He will be able to advise you on the cost. Rich I have tried but the website is down, I'll have a more comprehensive search later. - I'm off to a 914 meet in 10 minutes (IMG:style_emoticons/default/smile.gif) SirAndy has a great picture of the installed unit that was available as an option back in the day for the 914... Rich I never realised they were a factory option on a 914....... Sirandy, please post that pic (IMG:style_emoticons/default/pray.gif) I never said factory.... they were an aftermarket option. Rich |
Here's the pic Andy posted.
Attached image(s) ![]() |
lotus_65 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region ![]() |
i didn't go for a cl "stewart warner" one for $60.00.
what's the market value? (i'm reading further, this appears to be a dealer installable one.) This post has been edited by lotus_65: Sep 16 2009, 07:36 PM |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Has anyone here ever tried using one of these as a heat exchanger replacement?
http://www.aircraftspruce.com/catalog/eppa...rsheatmuffs.php I used one on my plane and it was great. I think the EGT's between a Lycoming and our engines would be comparable. In lower Slobovia you might install 1 on each side. BTW you can make your own out of an old butane or mapp gas canister. I made one but opted for the lighter weight aluminum model. You can add some small chain or wire rope around the exhaust pipe then clamp the heater box over the chain. This adds mass and will somewhat compensate for temperature variations as a result of deviations in power settings. i.e. cruise vs. coasting. As far getting heat to the front fan unit, has anyone tried using a cheap 12v ceramic heater for this? I see your in the UK. AC Spruce's rep in the UK is Pete Smoothy: PO Box 1835, Winslow England MK18 3ZS LOCATION P.O. Box 1835 Winslow, MK18 3ZS UK CONTACTS Ph: (44) 01 296 714 900 Fax: 01 296 713 303 e mail: sales@airworlduk.com |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Has anyone here ever tried using one of these as a heat exchanger replacement? http://www.aircraftspruce.com/catalog/eppa...rsheatmuffs.php I used one on my plane and it was great. I think the EGT's between a Lycoming and our engines would be comparable. In lower Slobovia you might install 1 on each side. BTW you can make your own out of an old butane or mapp gas canister. I made one but opted for the lighter weight aluminum model. You can add some small chain or wire rope around the exhaust pipe then clamp the heater box over the chain. This adds mass and will somewhat compensate for temperature variations as a result of deviations in power settings. i.e. cruise vs. coasting. As far getting heat to the front fan unit, has anyone tried using a cheap 12v ceramic heater for this? I see your in the UK. AC Spruce's rep in the UK is Pete Smoothy: PO Box 1835, Winslow England MK18 3ZS LOCATION P.O. Box 1835 Winslow, MK18 3ZS UK CONTACTS Ph: (44) 01 296 714 900 Fax: 01 296 713 303 e mail: sales@airworlduk.com Using those "heat muffs" for heat exchanger replacements is a great idea....... I have a pilot's license, and this never came to mind.... (IMG:style_emoticons/default/headbang.gif) As for the ceramic heater.. I used one for a while. It works, but the alternator on a 914/4 can't keep up with it and all the other electrical accessories. It was winter, and I had to plug in the battery charger every night to keep the battery up because of the heater. Good heat though. |
Challe |
Member ![]() ![]() Group: Members Posts: 60 Joined: 25-September 07 From: Sweden, Europe Member No.: 8,149 ![]() |
When I bought my 914 there was a Ebersprecher in the front of the passanger seat, fulel line and exhaust was drilled thru the floor. The unit was one more modern unit from the 80ies so it was far smaller then the one I have used in my VW bugs.
![]() I only use the car in the summer an when the unit started to fail I toked it out |
Lo-Fi Version | Time is now: 26th June 2024 - 09:00 AM |
