x6in6flames6x |
Newbie ![]() Group: Members Posts: 18 Joined: 17-October 07 From: shoreline, wa Member No.: 8,237 Region Association: Pacific Northwest ![]() |
is the easiest way the get to the lines underneath through that tiny hole behind the plate? or to pull the gas tank?
ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
I'm a big guy with big hands, so the only way I even try to get to the fuel lines is to pull the tank. The good news is that I can pull a fuel tank in about 20 minutes now.
Eric |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
The good news is that I can pull a fuel tank in about 20 minutes now. (IMG:style_emoticons/default/agree.gif) Pulling the tank is pretty straight forward ... If you make the new fuel lines about a foot long, you'll be able to pull up the tank without having to disconnect the lines first. Much easier that way! (IMG:style_emoticons/default/driving.gif) Andy |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I pulled 2 Gas tanks yesterday, each took 15-20 mins by myself in the hot cali sun. Its alot easier to work with the tank out. Also, that access hole is a favorite spot for black widows, both cars yesterday had more then right under the tank when I pulled them. It could be the seals on the bottom of the tanks, or your old fabric hoses need to be replaced. When replacing them try not to make them too long as they will want to kink when putting the tank back in. 12 -14 inches is a perfect length. If you get it most of the way out and it seems like its caught on something, that would be the fuel tank level sender wires stopping the tank.
x6in6flames6x |
awesome, thanks guys. found the leak already just needed to know the best plan of action.
luckly we dont have many black widows in the PNW. again, thanks for the input! |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I can do one in 20 min's...............Now! That first one took a taddddd longer.
Lo-Fi Version | Time is now: 25th June 2024 - 08:57 PM |
