TC 914-8 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 812 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest ![]() ![]() |
I haven't been a big fan of the "tuner" exhaust systems as of late. but my existing 2 1/2" pipes looked like pea shooters. So I broke down and picked up 2 - 3 1/2 " resinator tips. They look much better and give the new V-8 a deep droan.
![]() Old 2 1/2 " tips ![]() New 3"+ tips |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
(IMG:style_emoticons/default/aktion035.gif) looks nice
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
That will leave a nasty burn...
Be careful... |
computers4kids |
Love these little cars! ![]() ![]() ![]() ![]() Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None ![]() |
Looks good Tony (IMG:style_emoticons/default/beerchug.gif) So how is your car running since you put the new motor in? Haven't seen any pictures? Inquiring minds want to know.
TC 914-8 |
Looks good Tony (IMG:style_emoticons/default/beerchug.gif) So how is your car running since you put the new motor in? Haven't seen any pictures? Inquiring minds want to know. Hi Mark, All is well. I have about 350 mi. on it now. Seems to be running strong with good oil pressure, lots of power and plenty of revs. So today I go for a Sunday drive into town, I hear this squeeling sound while cruzing sown the road. I shut it down and pull over. I opened the engine lid and restart it. I could hear a dry squeel with a slight crunching noise. (IMG:style_emoticons/default/icon8.gif) I shut it down again. Good oil press, temps OK. I realize I'm on empty so I needed to make it to the gas station if I want to make it back home. The noise is gone (IMG:style_emoticons/default/WTF.gif) So I continue to go to town, All's ok. Temp running a little hi, 200* usually 180*. Oil press id good. Drove home gingerly but it ran good. I checked the play in the alternator, and remote water pump pulleys, all OK. Still, no more noise. So with the temp running higher than normal I'm hoping it's the water pump acting up. I have to go out of town for a couple of days. When I get back I'll pull the pump and Alternator for inspection. Hope that was it. All in all thanks for your help, Let me know when you head this way to see the inlaws. Tony |
6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
What a guy will go through for a extra 1/2 inch (IMG:style_emoticons/default/lol-2.gif) ........really it does look better
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
Tony,
They look good with your flares, and wider tires on the back. I think with a narrow body, they would look too big. Are your old ones chrome? I could use them on my Triad for a little different look if you don't want them. How is your spoiler on the trunk attached? Had one like that on my 70 years ago. Had it cut in half- removed a few inches so it just fit the width of the trunk lid- and had it glued in place. How is the new V8 doing? Tom |
TC 914-8 |
Tony, They look good with your flares, and wider tires on the back. I think with a narrow body, they would look too big. Are your old ones chrome? I could use them on my Triad for a little different look if you don't want them. How is your spoiler on the trunk attached? Had one like that on my 70 years ago. Had it cut in half- removed a few inches so it just fit the width of the trunk lid- and had it glued in place. How is the new V8 doing? Tom Hi Tom, I cut the old ones in half to fit the new ones over them, Not worth passing them on. The new V-8 is good, We need to plan a West sound get together.... T |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
If the motor was bored oversize sbc's tend to run hotter the thinner the cylinderwalls get. Also a new motor will be hotter than a broken in motor. You might want to get a stethescope and listen to the stuff you suspect before you start taking things off. Even if the squeel is gone a dry bearing will sound really loud with a stethoscope. Also listen to the top bushing in the dist it can get dry setting, it will usually turn and get the motor out of time when it galls though. If you suspect bearings you can check the oil for residue you know.
TC 914-8 |
If the motor was bored oversize sbc's tend to run hotter the thinner the cylinderwalls get. Also a new motor will be hotter than a broken in motor. You might want to get a stethescope and listen to the stuff you suspect before you start taking things off. Even if the squeel is gone a dry bearing will sound really loud with a stethoscope. Also listen to the top bushing in the dist it can get dry setting, it will usually turn and get the motor out of time when it galls though. If you suspect bearings you can check the oil for residue you know. Yep, I am dreading checking the oil. Oil Press is still strong though, so I am rulling out bearing issues,for now. I did think about Dist. but the noise came from the front of the engine. There was also a crunching noise along with the squeel. At this point, I would be happy to find water pump or Alt problems..... I'll know more later this week. Thanks for the input, T |
nsr-jamie |
914 guy in Japan ![]() ![]() ![]() Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None ![]() |
Looks awesome to me!! Anyway you can get a sound clip of the car starting up? That would be cool to hear.
Lo-Fi Version | Time is now: 25th June 2024 - 09:45 PM |
