Steering wheel can't remove HELP!, taken off before now won't come off |
thompson-mfr |
Sep 22 2009, 02:23 PM
Thompson, Ryan Group: Members Posts: 198 Joined: 30-September 08 From: Silverton, OR Member No.: 9,598 Region Association: Pacific Northwest |
PLEASE HELP
I am trying to remove my Steering wheel. It is an aftermarket one. I have an impact wrench and can get the nut off with no problem. I have removed the same steering wheel before, but now it won't pull off. I have pulled as hard as I can to no avail! If I pull any harder I may break the steering wheel. Any additional suggestions would be helpful. |
SLITS |
Sep 22 2009, 02:29 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Dynamite?
C4? A steering wheel puller? Keep wiggling it back and forth .. it should come off unless you somehow jammed the splines when you gunned it on with the impact wrench. |
McMark |
Put the nut back on until the top of the nut is level with the top of the threaded shaft.
Pull on the steering wheel while lightly tapping the nut/shaft. You may need to use your knees/legs to apply pulling pressure. It seems counter intuitive, but it'll work. |
thompson-mfr |
Sep 22 2009, 02:50 PM
tried this tapping/hammering a while ago with no success. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/headbang.gif)
it moves a little bit out (1/4 inch) then just stops can't get it past this point. |
Sleepin |
Sep 22 2009, 02:53 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Might have to use a puller then...and hope you didn't somehow screw up the splines.
SLITS |
Sep 22 2009, 02:54 PM
See, you pissed off Ferry by purchasing a non-Porsche part.
You might try a 3 finger puller if there is anything to hook onto. Harbor Freight ... 1 time use tool Other than that .... I gots nuthin' |
tradisrad |
Sep 22 2009, 03:22 PM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
was the wheel put on with the impact wrench? did the nut damage the splines? can you file them (splines) so the wheel slips off?
thompson-mfr |
Sep 22 2009, 04:01 PM
was the wheel put on with the impact wrench? did the nut damage the splines? can you file them (splines) so the wheel slips off? Yes I tightened the nut with an impact wrench. Don't know how that could damage the treads???? Wheel only moves 1/4 inch out then stops. |
thompson-mfr |
Sep 22 2009, 04:44 PM
Thanks for all the suggestions!
Someone mentioned a steering wheel puller (which I already have) but couldn't think of how to use it. Just thought of welding up a bracket to use with the steering wheel puller. (IMG:style_emoticons/default/welder.gif) The site is always good for jogging the memory. If that doesn't work then C4 will be next! (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) |
Drums66 |
Sep 22 2009, 04:54 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
[quote name='thompson-mfr' date='Sep 22 2009, 03:01 PM' post='1217392']
[quote name='tradisrad' post='1217379' date='Sep 22 2009, 02:22 PM'] was the wheel put on with the impact wrench? Yes I tightened the nut with an impact wrench. [/quote] That was a mistake.........Hide the impact wrench from yourself!! now you just have to play around with it.....punished (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/headbang.gif) |
thompson-mfr |
Sep 22 2009, 05:36 PM
Why is it SO bad to use a impact wrench to put the steering wheel nut back on? (IMG:style_emoticons/default/idea.gif)
jt914-6 |
Sep 22 2009, 05:55 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Why is it SO bad to use a impact wrench to put the steering wheel nut back on? (IMG:style_emoticons/default/idea.gif) Because of the current problem you have now.....I'm sure the torque specs aren't 100 ft. lbs...... (IMG:style_emoticons/default/shades.gif) |
ClayPerrine |
Sep 22 2009, 05:57 PM
Life's been good to me so far..... Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I wonder if Ron wishes he had this problem..... (IMG:style_emoticons/default/lol-2.gif)
ghuff |
Sep 22 2009, 07:23 PM
This is certainly not what I expected down here. Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
Why is it SO bad to use a impact wrench to put the steering wheel nut back on? (IMG:style_emoticons/default/idea.gif) Because you exceeded the torque spec by a ton. Spray some wd40 or penetrant down and tap back down with a hammer then work it back up. |
thompson-mfr |
Sep 22 2009, 09:56 PM
I made sure it would come off!!!! (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/headbang.gif)
I guess I figured it was taken off with a impact wrench, so I should put it back on with one. Who can argue with that dumb logic. Thanks for all the suggestions and advice!! I will try som PB Blast and a hammer first before I make the adapter for my steering wheel puller. |
Lo-Fi Version | Time is now: 25th June 2024 - 09:58 PM |
