Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
If there is positive pressure inside the cooling shroud, wouldn't these seal better if they where pushed inside the cooling shroud? I've always installed them on the outside. Do you?
Attached image(s) ![]() |
krazykonrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,129 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 ![]() |
The bigger "flange" for lack of a better word should be on the outside with the smaller one inside. You are probably right that it would seal better the other way around, but the way the rubber bits get mis-shapen, it probably doesn't matter anyway.
Konrad |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Hey, that's a good idea. (IMG:style_emoticons/default/tooth.gif)
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,471 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
I always put the bigger flap on the inside. I just thought it was supposed to go that way.
The #2 cylinder does not quite seal, but all the other seal way better then with the flap on the out side (the #2 seals better too, just not perfectly.) My plug wires only have the one big flap, not a smaller inside flap. My earlier set of wires did not have the smaller flap either... Zach |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,260 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
I was going to make some fiberglass covers that fit the sheetmetal real tight and have a hole for the wire to thread thru. They'd be held in place by a sheetmetal screw.
It's on my bucket list.... (IMG:style_emoticons/default/biggrin.gif) |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,516 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
JMHO, but maybe that seal has another purpose? Maybe to keep things out? Water? But if it is just for an air seal; I gotta agree w/ you Elliott.
Sealing w/ pressure rather than against pressure makes sense. |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
...Until they get brittle from the heat and then break off inside the shroud the next time you pull a plug wire...
You can put them inside if you like - I am not the spark plug air seal police. Since T-IV sheet metal is curved in that area a good seal is problematic anyway. "Supposedly" you can slide them up and down on the connector a bit to improve their loading against the shroud. Probably you'll find they're already too brittle for this. Some of the plug makers (Magnecore comes to mind) have nice seals of heat-resistant rubber with the small inner flange and a large outer flange designed to snap into the hole and stay there. I haven't tried them on a T-IV so I can't say they're actually better in this regard. |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
Another use for duck tape? Hee, heee. Just kidding. My new wires came with nice ones and seem to seal just fine. Had them off yesterday checking the plugs. That anti- seize I used 2 years ago sure worked well, plugs came out easy as pie.
Tom |
Lo-Fi Version | Time is now: 23rd June 2024 - 02:10 PM |
