91420L |
Newbie ![]() Group: Members Posts: 13 Joined: 14-March 05 From: Irvine, CA Member No.: 3,757 Region Association: None ![]() |
Thanks to current economy, I am forced to keep(and drive) my 914 even though my wife has objection to do so.
So now I am back in "Wanna work on something 914" mode again. (IMG:style_emoticons/default/biggrin.gif) It may have been discussed in the passed but could not find answer from thread serch. I would like to widen both fron and rear thread for just looking. I would like to keep 4lug fuchs so considering adding wheel spacers for them. Could I ask for advise if any of you have done it? If you have, which spacers and lug bolts have you had used for. 1. Spacers not recommend 2. Recommended spacer size for 4lug fuchs and source of parts. 3. Recommended lug bold size and source of parts. Thank you for your advise in advance! |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I would like to widen both fron and rear thread for just looking. I would like to keep 4lug fuchs so considering adding wheel spacers for them. Could I ask for advise if any of you have done it? If you have, which spacers and lug bolts have you had used for. 1. Spacers not recommend 2. Recommended spacer size for 4lug fuchs and source of parts. 3. Recommended lug bold size and source of parts. Thank you for your advise in advance! Never done it, but i think it would be better to go with studs and lug nuts rather than long bolts. Not sure if there's a lug nut out there that would fit the 4-bolt fuchs ... (IMG:style_emoticons/default/idea.gif) Andy |
siverson |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California ![]() ![]() ![]() |
I've wondered the same thing. I'd like to push the wheels out a little bit on my -4 with 165 tires...
-Steve |
blitZ |
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States ![]() |
I added a 1/4 inch aluminum spacer for my rear wheels as they were rubbing on the inside. To keep it safe, you'll need some longer bolts. I found some at Radus Direct. Ball seats for 914 stock wheels, Fuch and Mahle, are R14.
Cipi Wheel Spacers Lug Bolts |
91420L |
Thank you for information!
Lo-Fi Version | Time is now: 26th June 2024 - 06:04 AM |
