Sparky |
Mahna Mahna! ![]() ![]() ![]() Group: Members Posts: 1,134 Joined: 21-June 03 From: Spencer, MA Member No.: 847 ![]() |
A friend recently remodeled a small office and gave me the direct vent propane heater that had been used there. It's an Empire Gravity Direct Vent with a blower and thermostat. Can I just pick a wall and stick it in place with something like this as the cap/vent:
Simpson Dura-Vent Or do I really need a whole chimney setup for it? It's a 2 car garage that is decently insulated. I plan on keeping the tstat set to about 50 and bumping it up before I head out to work in the garage. The local propane company will "lease" me a 100lb. tank for free as long as I order 100lbs. of propane a year. I dont see that as an issue as I'll plumb it to the heater and my gas grill. Which brings up the next set of questions, what do I use for propane line? Can I pick it up at Lowes or HomeDepot? Trying to keep the budget down to avoid the dreaded S.S.S. (Screaming Spouse Syndrome). Any and all advise greatly appreciated!! My best, Mike D. |
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
Locally propane is plumbed with 3/8 soft copper tubing using flare fittings. The regulated pressure is the same so you can run your grille off the same tank. The gas company should know what you need for permits and inspections. And if its the big company that starts with "O" and ends in "n" be careful, they will screw you down the road.
Lo-Fi Version | Time is now: 20th June 2024 - 11:14 PM |
