Advice on media blasters...which one?, Let's go shopping... |
computers4kids |
Feb 24 2008, 09:31 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I'm looking at a variety of media blasters at Harbor Freight and could use any insights/experience to lead me to the best purchase for my needs (below).
A: I have come to a point in my project that I have the underside of both trunk lids and the door jambs that need to be prepped for paint. A real crappy paint job was sprayed on at one time. (rest of car has been stripped, reworked, sealed) B: Lots of little parts that I would like to bead blast and paint/powdercoat before the car goes back together. C: Picked-up a set of 2ltr alloys that I would like to bead blast the backsides to clean-up before I polish them. Not to sure if I should bead blast the front before polishing. I'm not going to send them out. Last set I wet sanded and polished the hard way, but they turned out real nice. Not sure if bead blasting would help or make more work for me. Here are the choices I have and current prices at HF..some on sale. What do you think? Blaster Gun 16 sale (19.99)...would take alot of refilling but price is right? 35 gallon with vacumm 249 (not on sale) 40 pressurized 79 sale (129) 110 pressurized 119 sale (199) cabinet 69 sale (87)...not sure if you can connect a hose for bigger stuff? gravity feed (top load) unit 119 sale (139) Attached thumbnail(s) |
race914 |
Feb 24 2008, 10:18 AM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
I've got the 40lb pressurized unit. It works pretty good but you need a high capacity air compressor to keep up with it. I have a Craftsman 5hp 25gal compressor that delivers 7.1 scfm @90psi and it can't keep up.
computers4kids |
Feb 24 2008, 12:57 PM
I've got the 40lb pressurized unit. It works pretty good but you need a high capacity air compressor to keep up with it. I have a Craftsman 5hp 25gal compressor that delivers 7.1 scfm @90psi and it can't keep up. Good Point...I have a Charge Pro 220 volt 5 hp 60 gallon compressor. I am able to run a DA for hours (if I'm possessed enough) at 90 psi and it always keeps up and even catches-up and turns off. So I figure it should run a media blaster just fine. Not sure what the scfm is. Just curious...how long does say a 40lb load last? |
Lo-Fi Version | Time is now: 20th June 2024 - 09:20 AM |
