stephenaki |
Can I get this one dad?? ![]() ![]() ![]() Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None ![]() |
OK, my understanding is that the washer system uses air from the tires to shoot the water solution onto the windshield. AA sells an electric replacement for $200 some odd.
Has anyone used a straight aftermarket system vice the AA system? Does anyone see an issue with say pulling a system off of another car and wiring it in to a 914? Looking for options. I am sure the AA system is top notch but i'm a a cheap Chinaman and just need it to function for the next couple of years until I can get it back to the states and REALLY work on it. |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,163 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
My switch mount was designed in SolidWorks and printed in ABS on a rapid prototyping machine. The switch should have enough current capacity to directly run a pump. Run some wires, get a Rabbit pump, and do a modification of the tank, and never have to worry about fluid spurting out of the steering column. The switch is designed to be a true bolt-in replacement for the valve. I have a few available.
Lo-Fi Version | Time is now: 1st July 2024 - 05:05 AM |
