stephenaki |
Can I get this one dad?? ![]() ![]() ![]() Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None ![]() |
OK, my understanding is that the washer system uses air from the tires to shoot the water solution onto the windshield. AA sells an electric replacement for $200 some odd.
Has anyone used a straight aftermarket system vice the AA system? Does anyone see an issue with say pulling a system off of another car and wiring it in to a 914? Looking for options. I am sure the AA system is top notch but i'm a a cheap Chinaman and just need it to function for the next couple of years until I can get it back to the states and REALLY work on it. |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,163 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
My switch mount was designed in SolidWorks and printed in ABS on a rapid prototyping machine. The switch should have enough current capacity to directly run a pump. Run some wires, get a Rabbit pump, and do a modification of the tank, and never have to worry about fluid spurting out of the steering column. The switch is designed to be a true bolt-in replacement for the valve. I have a few available.
stephenaki |
My switch mount was designed in SolidWorks and printed in ABS on a rapid prototyping machine. The switch should have enough current capacity to directly run a pump. Run some wires, get a Rabbit pump, and do a modification of the tank, and never have to worry about fluid spurting out of the steering column. The switch is designed to be a true bolt-in replacement for the valve. I have a few available. OK, Edumicate me. The wiper switch on the column can not be used to run an aftermarket system? I saw the comment about water squirting out of the steering column and have read through the set up and external switch. Is the column lever not an electrical connection that activates the stock system? Trying to understand the set up as I like simplicity and would prefer to keep the activation of the washer tied to the column switch. |
Lo-Fi Version | Time is now: 1st July 2024 - 04:24 AM |
