rusty e-brake handle, is removal possible? |
scrz914 |
Mar 3 2008, 05:57 PM
Member Group: Members Posts: 406 Joined: 21-April 04 From: Santa Cruz, CA Member No.: 1,960 Region Association: Central California |
Floor boards have rust issues. One spot is under and behind the e-brake handle. This bugger won't come off. Removal without (IMG:style_emoticons/default/sawzall-smiley.gif) destuction seems impossible.
Has anyone had success taking off rusty handles? Is there a lock washer that I'm missing? ( yes, I unbolted the cam ). I would also take off the handle to clean and repaint. It squeeks and is pretty tough to move up and down. I'm guessing is has the same type of plastic bushings that the pedal clusters have. Is this part replaceable or do I need to buy a new $200 handle, if they exist? Thanks for the help. I know this is a common problem for a lot of 914s. Tony |
jim_hoyland |
Mar 3 2008, 08:54 PM
Get that VIN ? Group: Members Posts: 9,571 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Floor boards have rust issues. One spot is under and behind the e-brake handle. This bugger won't come off. Removal without (IMG:style_emoticons/default/sawzall-smiley.gif) destuction seems impossible. Has anyone had success taking off rusty handles? Is there a lock washer that I'm missing? ( yes, I unbolted the cam ). I would also take off the handle to clean and repaint. It squeeks and is pretty tough to move up and down. I'm guessing is has the same type of plastic bushings that the pedal clusters have. Is this part replaceable or do I need to buy a new $200 handle, if they exist? Thanks for the help. I know this is a common problem for a lot of 914s. Tony If you are going to repaint it, the plastic handle can be a bear to remove. I got mine off pretty easy by hanging the lever with handle grip down; squirt PB Blaster where the plastic handle meets the metal. Think I did this over 2 days. Plastic handle slid off with some twisting. |
Lo-Fi Version | Time is now: 6th January 2025 - 05:35 PM |
