Thack |
Member ![]() ![]() Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 ![]() |
For those running dual carbs, how do you attach a crankcase breather hose to the filters? Especially if you have K&Ns, which I plan to replace. Do you run two hoses? Got pics? (IMG:style_emoticons/default/sawzall-smiley.gif)
akellym |
Eyes Of The Deep Battle ![]() ![]() ![]() Group: Members Posts: 597 Joined: 25-July 04 From: Annandale, MN Member No.: 2,395 Region Association: Northstar Region ![]() |
this works very well for me.
pete914 |
Member ![]() ![]() Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 ![]() |
sirandy,
so you have one line from oil filler to puke box...two lines from puke box to each valve cover? what kind of fastener grommets are you guys using? it would be so, so, so bad if that came loose in there. further, must have to be a tight fit to keep the dirt out... thanks for your help. just want to do this right the first time... by the way...very nice looking engine bay akellym |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
sirandy, so you have one line from oil filler to puke box...two lines from puke box to each valve cover? what kind of fastener grommets are you guys using? it would be so, so, so bad if that came loose in there. further, must have to be a tight fit to keep the dirt out... almost ... oil filler to puke box ... stock head vents to puke box ... no need to mess with the valve covers if you have heads that have the stock vent setup. i forget which years had the head vents (IMG:style_emoticons/default/shades.gif) Andy green arrow points to the vent hole. it has a insert that you simply clamp the hose to ... Attached image(s) ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 12:06 AM |
