Thack |
Member ![]() ![]() Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 ![]() |
For those running dual carbs, how do you attach a crankcase breather hose to the filters? Especially if you have K&Ns, which I plan to replace. Do you run two hoses? Got pics? (IMG:style_emoticons/default/sawzall-smiley.gif)
ruddyboys |
Hummel eigentümer ![]() ![]() ![]() Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States ![]() |
my engine doesn't have either head vents or valve cover vents, if I put these nipples on my valve covers would it stop the leaking from around the top of the push rod tubes? And yes I have tried to replace the O-rings, but have the old '70 heads with smaller pushrod tube openings that have no longer made original O-rings, had to go to FLAPS and even hardware stores to try to find ones that are close. Using a sealant that Jake mentioned has helped a lot.
pete914 |
Member ![]() ![]() Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 ![]() |
ruddyboys: I bet venting would help. Its the pressure along with bad push rod seals thats probably causing the leakage...
Well, I might start with something like Gint's setup and then consider venting to the valve covers. I know that this is a different setup then the factor FI (running carbs), but if the engineers didn't think it was necessary for the engine to have any additional venting other than the oil cap filler, perhaps that single vent is adequate. Also, were is the condensing oil going to go once it gets inside the valve covers? Everytime I've adjusted my valves it doesn't seem like there is any oil in there... |
Lo-Fi Version | Time is now: 26th June 2024 - 12:27 AM |
