Thack |
Member ![]() ![]() Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 ![]() |
For those running dual carbs, how do you attach a crankcase breather hose to the filters? Especially if you have K&Ns, which I plan to replace. Do you run two hoses? Got pics? (IMG:style_emoticons/default/sawzall-smiley.gif)
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,631 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
I use this CFR Spunone collaboration. The two side hoses come from the heads and the bottom front exit comes from the oil filler tower. The can is fuel cell foam filled. The oil vapor drains down into the can and then back into the engine.
A very nice set up. Though Chris wants to make at least ten at a time. I bought another set up but decided not to use it. It would require T fittings to combine the hoses from the three vent locations and it has a petcock to drain the collected oil. I paid over $100 for it. $75 shipped to whoever wants it. New... Attached image(s) ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 01:52 AM |
