Michael N |
Certifiable ![]() ![]() ![]() Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California ![]() |
I am getting ready to install Koni sports with a Rebel Racing 2.25" ID spring coilover kit. I have Eibach 8" 200lbs springs to go with the set up. Using the search function I see that most coilover kits with the threaded perches are using 10" springs. Will the 8" springs I have still give me the same results by adjusting the collar?
Attached thumbnail(s) ![]() |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
As long as you can run the nuts up high enough on the threaded collars, they should work fine.
One thing that I do is tie the spring up to the upper spring "hat". This keeps the spring seated in the "hat" when the car is in the raised position so that when you set the car back down on the ground, you don't have to worry about it not being seated. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:05 AM |
