naro914 |
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States ![]() |
I thought I would share the latest upgrade we've done to Papa Smurf.
Over the years, the Carrera suspension on our 914 has been getting a bit "soft". the springs were shot - one was up higher on the perch in the back than the other, and all 4 shocks were leaking. So, after finally putting the budget together to get it all corrected, we took the plunge last month... If any of you followed the build of Matteo Amoroso's killer 911 RSR build on Pelican Parts, or read about it in Excellence, you know it was built by Zuffenhaus here in Charlotte. One day while it was up on the lift, I noticed the wonderful front end suspension on it. So, I inquired, and started down the slippery slope to emptying my bank account. What we now have is the 935 suspension conversion, with Fox remote resevoir coil overs all around, welded in camber boxes and adjustment plates, 375 springs around, reinforced rear trailing arm, monoball, and probably a bunch of other things I don't know about. the work took about 2 weeks with all the cutting and welding, installation, etc. We drove it on the track a week and a half ago to start sorting it out. We lowered the car another 1", and were finally able to give it some negative camber (we had not been able to adjust the camber enough at the height we wanted before) Right off the bat I noticed how much easier the steering was, and how much more responsive the handling was. We found we needed to take off the rear sway bar as I was getting a lot of rear wheel hop in fast corners (no, I don't have LSD yet....next years budget) It was an absolute joy to drive. My wife, Nadine, even commented how easy is was. I went were we pointed it. It stuck MUCH better than it ever had. We spent the weekend tweeking and tuning out anything we could find. And we really noticed the changes. Money well spent!! Here are a few pictures of the suspension from right after we got home. Excuse how dirty it is...it got a lot of track time in 2 days! Attached image(s) ![]() ![]() ![]() |
naro914 |
Someone PM'd me about the brakes....
They are 993 rear brakes on the front. The mounting holes on the calipers ALMOST fit the normal spindle mounts - you have to wallow out the holes on the calipers about 1/4 inch to the inside of each, but that's it. I'm even using the Carrera rotors I had from before. Been using this set up for a year now, on both 914's. Stopping is amazing....stops like a 993, very firm pedal, not a lot of pedal travel. Slowly but surely, Papa Smurf is getting done....only taken 15 years so far! |
Lo-Fi Version | Time is now: 26th June 2024 - 11:25 AM |
