Anyone with a phone number, knows how to remove a clutch cable... |
redshift |
Dec 23 2003, 10:19 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
...from the GD pedal cluster? PM me..
I lost the accel cable down the f'n tunnel.. next move is sawzall vs tunnel... I'm beyond caring if it's fixed right, I just need it to drive. What is removed? I can't even see it all. What kind of idiot invented this rubick's cube POS? M |
Gint |
Dec 23 2003, 10:53 PM
Mike Ginter Group: Admin Posts: 16,095 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
PM'd ya with a number. You're probably already on the phone with someone. Remove the cable from the fork at the trans (self-explanatory). Push the cable forward in the sleeve to give some slack. At the pedal arm, the cable end has a spring clip that wraps partially around the cable. It's connected to the pin that goes through the end of the cable fork. Pop that spring clip loose, and then you can pull the pin from the fork. You're done.
Lo-Fi Version | Time is now: 5th February 2025 - 12:00 AM |
