> Pilot bearing in the crank, is this going to be an issue?
VaccaRabite
post Mar 15 2008, 03:16 PM
En Garde!
Isn't this bearing supposed to be in the flywheel?
How do I get the bugger out?
What should I do here?
(IMG:http://farm4.static.flickr.com/3182/2335190315_28837f1729.jpg)
If it is not an issue, please let me know. Its in there pretty good. I figure I am going to have to weld a bolt to it to get it out. Right now, I have no purchase.
Zach
Krieger
post Mar 15 2008, 09:12 PM
Put a couple of bolts in the end of the fw and use those and a big screw driver to pry it out. I made this mistake too. Although I do have a bus fw that had to be machined for the pilot bearing. I bet you have a slight mark/groove on the end of the trans input shaft. Putting the bearing in the correct location solved my tranny leak. I think you could leave it in with no ill effects.
Vacca Rabite   Pilot bearing in the crank   Mar 15 2008, 03:16 PM
brp986s   the pilot bearing goes in the flywheel, not the cr...   Mar 15 2008, 04:01 PM
SirAndy   the pilot bearing goes in the flywheel, not the c...   Mar 15 2008, 04:32 PM
McMark   Get some bearing grease and pack, pack, pack it in...   Mar 15 2008, 04:24 PM
Vacca Rabite   Anyone have a good reason not to just leave that ...   Mar 15 2008, 04:39 PM
brer   There is a spacer that goes in the crank and its n...   Mar 15 2008, 04:51 PM
BIGKAT_83   Get some bearing grease and pack, pack, pack it i...   Mar 15 2008, 05:13 PM
Mark Henry   Dude it comes out real easy. I use a autobody slid...   Mar 15 2008, 05:38 PM
Krieger914   Put a couple of bolts in the end of the fw and use...   Mar 15 2008, 09:12 PM
brer   +1 for grease and tight fitting rod, or better yet...   Mar 15 2008, 09:55 PM
LvSteveH   For what it's worth I had a car running dual p...   Mar 15 2008, 10:45 PM
davep   The 411, at least, had the bearing in the crank li...   Mar 16 2008, 08:30 AM
Gint   Seems like you could cut the cage with a saw blade...   Mar 16 2008, 08:57 AM
brer   there is also that felt washer that goes in. with...   Mar 16 2008, 09:59 AM
davep   Well, the bearing in his photo is not properly sea...   Mar 16 2008, 06:35 PM
Vacca Rabite   Well, I treid the grease trick last night to pop t...   Mar 28 2008, 11:58 AM
brer   you could have better luck putting some heat shrin...   Mar 28 2008, 12:09 PM
jkeyzer   this is one of those things where if you take a sh...   Mar 28 2008, 12:11 PM
Cap'n Krusty   All this verbiage, and not much in the way of a re...   Mar 28 2008, 12:42 PM
davep   It's likely that the T4 with a manual tranny ...   Mar 28 2008, 08:35 PM
Krieger914   Don't worry about it. If you put another bear...   Mar 28 2008, 02:32 PM
- Lo-Fi Version Time is now: 31st October 2024 - 07:27 PM
