> Pilot bearing in the crank, is this going to be an issue?
VaccaRabite
post Mar 15 2008, 03:16 PM
En Garde!
Isn't this bearing supposed to be in the flywheel?
How do I get the bugger out?
What should I do here?
(IMG:http://farm4.static.flickr.com/3182/2335190315_28837f1729.jpg)
If it is not an issue, please let me know. Its in there pretty good. I figure I am going to have to weld a bolt to it to get it out. Right now, I have no purchase.
Zach
davep
post Mar 16 2008, 08:30 AM
914 Historian
The 411, at least, had the bearing in the crank like that since the flywheel was too shallow. The 914 has the spacer ring in there, and the bearing in the flywheel. I agree that a bearing in both places is not a problem PROVIDED that both bearings are functional.
Vacca Rabite   Pilot bearing in the crank   Mar 15 2008, 03:16 PM
brp986s   the pilot bearing goes in the flywheel, not the cr...   Mar 15 2008, 04:01 PM
SirAndy   the pilot bearing goes in the flywheel, not the c...   Mar 15 2008, 04:32 PM
McMark   Get some bearing grease and pack, pack, pack it in...   Mar 15 2008, 04:24 PM
Vacca Rabite   Anyone have a good reason not to just leave that ...   Mar 15 2008, 04:39 PM
brer   There is a spacer that goes in the crank and its n...   Mar 15 2008, 04:51 PM
BIGKAT_83   Get some bearing grease and pack, pack, pack it i...   Mar 15 2008, 05:13 PM
Mark Henry   Dude it comes out real easy. I use a autobody slid...   Mar 15 2008, 05:38 PM
Krieger914   Put a couple of bolts in the end of the fw and use...   Mar 15 2008, 09:12 PM
brer   +1 for grease and tight fitting rod, or better yet...   Mar 15 2008, 09:55 PM
LvSteveH   For what it's worth I had a car running dual p...   Mar 15 2008, 10:45 PM
davep   The 411, at least, had the bearing in the crank li...   Mar 16 2008, 08:30 AM
Gint   Seems like you could cut the cage with a saw blade...   Mar 16 2008, 08:57 AM
brer   there is also that felt washer that goes in. with...   Mar 16 2008, 09:59 AM
davep   Well, the bearing in his photo is not properly sea...   Mar 16 2008, 06:35 PM
Vacca Rabite   Well, I treid the grease trick last night to pop t...   Mar 28 2008, 11:58 AM
brer   you could have better luck putting some heat shrin...   Mar 28 2008, 12:09 PM
jkeyzer   this is one of those things where if you take a sh...   Mar 28 2008, 12:11 PM
Cap'n Krusty   All this verbiage, and not much in the way of a re...   Mar 28 2008, 12:42 PM
davep   It's likely that the T4 with a manual tranny ...   Mar 28 2008, 08:35 PM
Krieger914   Don't worry about it. If you put another bear...   Mar 28 2008, 02:32 PM
- Lo-Fi Version Time is now: 31st October 2024 - 07:24 PM
