> Measures for flare installation, i need some figures for my flare installation
sechszylinder
post Mar 16 2008, 10:42 AM
Hello folks,
I'm in the progress installing flares on my current project car. I've browsed thru the various threads describing the installation processes itself, but I found only one picture with some rough measures (it's a hand sketch, with measures for 916 and 914/6 GT) for the positioni of the flares to the fender.
The problem is that I'm not able to adjust the flares against the wheels or against the front valance cause the car is completely stripped down, so I have to rely on pure measures.
It would be absolutely fantastic, if someone could provide me with the dimensions for the distance A and B (only front fender this time ;-) ), which I've marked in the attached picture.
Based on those dimensions I would prepare an exact sketch, which could be used in the future .
best greetings from Germany (IMG:style_emoticons/default/smilie_flagge6.gif)
Benno
PRS914-6
post Mar 16 2008, 01:13 PM
Excellence Magazine Project 914 3.6
Group: Retired Members
The problem is that every rocker brand, front valance, flare etc. is slightly different. I found the best way is to have all parts in hand and mount the flare where it will require the least amount of work to make them all fit properly and flow into each other the way they should. Not an easy task and if not adjusted accordingly, you could spend hours (or days) making the other components fit.
The measurement you ask would be different for every situation.....
- Lo-Fi Version Time is now: 31st October 2024 - 08:21 PM
