Optima's PC680... help please, Mounting help needed |
PeeGreen 914 |
Mar 17 2008, 08:35 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
So I just bought a PC680 and am wondering about mounting. I know you can mount it on its side and I was going to do that in the original battery tray. Anyone have pictures of what you did? Also needing pictures of different quick disconnects and how you mounted those.
Thanks |
PeeGreen 914 |
Mar 17 2008, 08:49 PM
Thanks Rand, That's what I wanted to see (IMG:style_emoticons/default/biggrin.gif) Now I need to go buy some stuff. So how does one use these? Does it matter what kind I get? I know I can get one at Action Auto for $20 but is that going to be fine? How did you mount it on your car?
Attached image(s) |
tango-52 |
Mar 17 2008, 09:38 PM
Member Group: Members Posts: 149 Joined: 18-October 07 From: San Diego County Member No.: 8,243 Region Association: Southern California |
So how does one use these? Does it matter what kind I get? I know I can get one at Action Auto for $20 but is that going to be fine? How did you mount it on your car? It is basically a battery off/on switch. If this is for racing, check your sanctioning body to see if they have specific requirements on its location. It should be accessible and easily visible to rescue workers so they can shut the power off to the engine and primarily to the fuel pump. Make sure that the one you get is large enough in capacity to handle all the power that will be going through it. If it is only running the igintion, F.I. and fuel pump, then it won't need to be as big as if the starter also goes through it. Connect a lead from the battery to one of the posts, and everything that you want to shut off to the other post. Cover the posts with racers tape after you are done, to keep anything from bumping into it by accident. The red key on top is removable, so attach it to the car with a length of safety wire. If, on the other hand, you are using it for a security device, hide it somewhere convenient and route the ignition and fuel pump to it. Then take the key with you when you park it. |
Lo-Fi Version | Time is now: 25th September 2024 - 10:51 PM |
