drue |
Newbie ![]() Group: Members Posts: 11 Joined: 9-October 07 From: Indianapolis Member No.: 8,202 ![]() |
I've got a 1975 914/4 and I haven't been able to shift into first gear for quite awhile. I got under the car and tried doing it manually and was able to do it so I know first gear works. But for the life of me, I can't seem to adjust it to shift into first. Every time I try shifting into first gear, it grinds until I quit trying. And it's such a hassle to crawl under the car and shift into first at every stop light (IMG:style_emoticons/default/dry.gif) .
I've followed the suggestions in Kevin's post but I still can't seem to make it work. Has anyone else had this problem? It shifts into every other gear without any problem. |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
so is it that you can shift it into first with the engine off only/and only by at the shifter consul [under the car at the tranny]?
can you shift it into first with engine on from under the car? |
drue |
so is it that you can shift it into first with the engine off only/and only by at the shifter consul [under the car at the tranny]? can you shift it into first with engine on from under the car? I only tried it with the engine off. What would it mean if I can (or can't) do it with the engine on, would that mean the clutch needed adjustment? |
Lo-Fi Version | Time is now: 24th June 2024 - 06:59 AM |
