drue |
Newbie ![]() Group: Members Posts: 11 Joined: 9-October 07 From: Indianapolis Member No.: 8,202 ![]() |
I've got a 1975 914/4 and I haven't been able to shift into first gear for quite awhile. I got under the car and tried doing it manually and was able to do it so I know first gear works. But for the life of me, I can't seem to adjust it to shift into first. Every time I try shifting into first gear, it grinds until I quit trying. And it's such a hassle to crawl under the car and shift into first at every stop light (IMG:style_emoticons/default/dry.gif) .
I've followed the suggestions in Kevin's post but I still can't seem to make it work. Has anyone else had this problem? It shifts into every other gear without any problem. |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
if its the clutch you should be able to shift to first with the engine off from the shifter in the car, if it's the syncro's and dogs you might be able to get to first by going to second or third first then first. or it could be all the above, clutch, shifter bushings, shifter adjustment, dogs and sycros, even the clucht cable tube tube.
Lo-Fi Version | Time is now: 24th June 2024 - 07:12 AM |
