drue |
Newbie ![]() Group: Members Posts: 11 Joined: 9-October 07 From: Indianapolis Member No.: 8,202 ![]() |
I've got a 1975 914/4 and I haven't been able to shift into first gear for quite awhile. I got under the car and tried doing it manually and was able to do it so I know first gear works. But for the life of me, I can't seem to adjust it to shift into first. Every time I try shifting into first gear, it grinds until I quit trying. And it's such a hassle to crawl under the car and shift into first at every stop light (IMG:style_emoticons/default/dry.gif) .
I've followed the suggestions in Kevin's post but I still can't seem to make it work. Has anyone else had this problem? It shifts into every other gear without any problem. |
Dr. Roger |
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California ![]() |
like troy said, if it isn't a clutch problem, you cna shift into second or third gear first, then quickly into first.
if that doesn't do it then it is probably the clutch. |
Lo-Fi Version | Time is now: 25th June 2024 - 07:31 PM |
