A&PGirl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None ![]() |
It rained very hard and almost continuously yesterday so I went out today to check the car. It had water where I usually see water and then where I have never seen it before. So, I vacuumed out the psgr's side then the driver's side. I noticed that the pedal cluster area was full of water despite the car sitting flat on the ground.
I cleared that out then worked on the water around the cross member. I cleaned it up on the front side and then turned to work on the rear. When I look back it is full of water again. (IMG:style_emoticons/default/WTF.gif) I look forward into the pedal cluster area, it is full. (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/WTF.gif) So, I sucked the water up in the pedal cluster area and crawled over to the other side. ![]() The water was right up against the center tunnel and across the front firewall. (Rust shows you). I cleaned it all out and water didn't appear again. I went back to the driver's cross member. This time I watched what happened after I sucked the water up. 30-50 seconds later, water came out of the cross member seam and long-to-floor seam and filled that area again. ![]() I checked again same thing happened. What is going on? The water came out of the cross members on both sides, the center tunnel and the driver's long-to-floor-cross member seam. There are no obvious holes or cracks, but there is surface rust where the water has come out. I don't have a clue what is going on. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:11 PM |
