scrz914 |
Member ![]() ![]() Group: Members Posts: 398 Joined: 21-April 04 From: Santa Cruz, CA Member No.: 1,960 Region Association: Central California ![]() |
As stated above.
I asked the local 914 mechanic about installing new brake hoses. He wasn't sure if stock 914 rubber or SS braided would work since I had BMW front calipers. For those that have BMW calipers, what have you installed for your brake hoses? I would like to get some of the SS braided but would hate to buy then find out there is a compatibility problem. Thanks for your help. |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,508 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Yes, actually it has nothing to do with the flex line. BTW: This caliper is mounted on the wrong side..
Attached image(s) ![]() |
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
rick 918-S |
Yes, actually it has nothing to do with the flex line. BTW: This caliper is mounted on the wrong side.. Is this from a Volvo? I remember Volvos having that dual brake line setup, but I don't remember any BMW's like that. Nope, BMW 2002 4 piston for solid rotors. They don't require machining to bolt onto a 1972 strut. The pads ride exactly where the 914 pads ride. The pads on the 320 calipers ride over the rotor. I had a set of those Volvo units. They were huge and heavy! Adding un-nesessary unsprung weight is not the way to go. |
Lo-Fi Version | Time is now: 20th June 2024 - 06:01 AM |
