A&PGirl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None ![]() |
It rained very hard and almost continuously yesterday so I went out today to check the car. It had water where I usually see water and then where I have never seen it before. So, I vacuumed out the psgr's side then the driver's side. I noticed that the pedal cluster area was full of water despite the car sitting flat on the ground.
I cleared that out then worked on the water around the cross member. I cleaned it up on the front side and then turned to work on the rear. When I look back it is full of water again. (IMG:style_emoticons/default/WTF.gif) I look forward into the pedal cluster area, it is full. (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/WTF.gif) So, I sucked the water up in the pedal cluster area and crawled over to the other side. ![]() The water was right up against the center tunnel and across the front firewall. (Rust shows you). I cleaned it all out and water didn't appear again. I went back to the driver's cross member. This time I watched what happened after I sucked the water up. 30-50 seconds later, water came out of the cross member seam and long-to-floor seam and filled that area again. ![]() I checked again same thing happened. What is going on? The water came out of the cross members on both sides, the center tunnel and the driver's long-to-floor-cross member seam. There are no obvious holes or cracks, but there is surface rust where the water has come out. I don't have a clue what is going on. (IMG:style_emoticons/default/confused24.gif) |
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
To find out if your windshield or rear window is leaking, spray soapy water all the way around the outside of the glass and blow compressed air from the inside out. If it's leaking it will make beautiful bubbles on the outside of the car.
Lo-Fi Version | Time is now: 23rd June 2024 - 12:51 PM |
