Wiring the Head Temp Sensor |
bobhasissues |
Mar 19 2008, 09:27 PM
seemingly endless issues with my 914 Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None |
I have a '73 that was originally a 1.7 but now has a carbureted 2.0. The EFI harness is gone and so is the head temp sensor. I have a head temp gauge and would like to install a new sensor. This car does not have the center console or harness in the tunnel. I would like to mount the gague on a gauge holder under the dash above the tunnel. The question is, how do I wire this thing up? I have the same situation with the Oil Temp Sensor if anyone could help with that as well.
Rand |
Mar 20 2008, 05:09 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
One wire from the sender under the spark plug to the gauge. No power source. Then a ground.
The switched power source would only be used for the light bulb if you want it illuminated - that's a separate circuit. |
Lo-Fi Version | Time is now: 24th September 2024 - 01:15 PM |
