scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Bought a set of EMPI carbs for a customers car. WHY Empis? Because after 2 weeks of unreturned calls to Weber direct we got fed up and called an Alfa supplier and he recommended the EMPIS. According to him they are as good as the Weber and is the same design. MY issue so far is the manifolds fit like SH*T I spent 30 minutes going from the car to the drill press reaming out ALL 4 holes to get the F-ers to fit.2 center holes had to be drilled out to 3/8" and the outer slots had to be drilled out to 3/8 AND lengthend. Was this a vision into the future (tommorrow) of how things will go when I start the car up ?
Once the manifolds were done everything else went fine. Is this a common issue and will the carbs end up being problematic? |
scotty b |
Everything was fine except the manifold to head bolt holes. Linkage is good but not the precision fit I personally would want. I haven't seen a REALLY nice linkage setup for these though so this may be the best there is (IMG:style_emoticons/default/confused24.gif) Typical hex bar setup though, I've just not been a fan of the loose fit machining on the ends and center piece. There always seems to be a loose sloppy fit on the arms that is kept in place mainly by the bolts pinching the arms down. I would just prefer a nice tightly machined "star".
Lo-Fi Version | Time is now: 28th June 2024 - 03:46 PM |
