scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Bought a set of EMPI carbs for a customers car. WHY Empis? Because after 2 weeks of unreturned calls to Weber direct we got fed up and called an Alfa supplier and he recommended the EMPIS. According to him they are as good as the Weber and is the same design. MY issue so far is the manifolds fit like SH*T I spent 30 minutes going from the car to the drill press reaming out ALL 4 holes to get the F-ers to fit.2 center holes had to be drilled out to 3/8" and the outer slots had to be drilled out to 3/8 AND lengthend. Was this a vision into the future (tommorrow) of how things will go when I start the car up ?
Once the manifolds were done everything else went fine. Is this a common issue and will the carbs end up being problematic? |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,702 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
are you getting some velocity stacks for those?
(IMG:style_emoticons/default/idea.gif) Andy |
scotty b |
No, the engine in all honesty is a time bomb. I don't want to go into details here but the P.O. "built" a 2056. I thought, and Mark confirmed, what he did is assemble a pile of cheap parts to create a 2056. He had a Weber progressive on the engine and I felt it best to go with the duals to stave off the inevitable. This car was a classic E-bay f-up. Had the guy contacted me first I could have asked one of you guys out in Cali to check this thing out and saved him a LOT of money. But in the end it is what it is and all I can do is try and get him alittle fun with it. I have already told him the engine s junk and to plan on a PROPER rebuld in the next year or 2 ( if he is lucky) Carbs were done as I said to give the engine what little help we could as well as planning for a GOOD 2056 build later. For those who saw it this is the car I was looking for info on a month or so ago. http://www.914world.com/bbs2/index.php?sho...504&hl=info |
pete914 |
Member ![]() ![]() Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 ![]() |
Scotty I would love to come by and take a look a this. Just put in a set of duals and I'm having some trouble with venting. Is there no PCV valve on the oil filler on this car. Are they not there on the 2.0?
Good looking install... |
scotty b |
Scotty I would love to come by and take a look a this. Just put in a set of duals and I'm having some trouble with venting. There's no PCV valve on the oil filler on this car. Are they not there on the 2.0? Feel free, but call me first to make sure I'm there ! Still got my number? |
Lo-Fi Version | Time is now: 24th June 2024 - 07:16 AM |
