scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Bought a set of EMPI carbs for a customers car. WHY Empis? Because after 2 weeks of unreturned calls to Weber direct we got fed up and called an Alfa supplier and he recommended the EMPIS. According to him they are as good as the Weber and is the same design. MY issue so far is the manifolds fit like SH*T I spent 30 minutes going from the car to the drill press reaming out ALL 4 holes to get the F-ers to fit.2 center holes had to be drilled out to 3/8" and the outer slots had to be drilled out to 3/8 AND lengthend. Was this a vision into the future (tommorrow) of how things will go when I start the car up ?
Once the manifolds were done everything else went fine. Is this a common issue and will the carbs end up being problematic? |
scotty b |
(IMG:style_emoticons/default/thumb3d.gif) Well I found enough time today to get the carbs plummed and I just couldn't resist an initial drive. UNTUNED, UNSYNCHED the thing fired up and idled fairly well. Good throttle response and a quick blast around the block was VERY promising. Only issue I noticed is that when you hoit about 4000 it feels like there is nothing more. TUNING TIME !! At this point my only complaint was and is the fitment of the manifolds. I'll get them synched and tuned later next week. To many collision jobs to get done first. The owner is anxious but very understanding about the delays. MAJOR improvement over the progressive that was on it.
Pete I'll not be at the shop Sat but will probably be there Sunday after 10:30 ish if you want to swing by |
Lo-Fi Version | Time is now: 28th June 2024 - 03:29 PM |
