scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Bought a set of EMPI carbs for a customers car. WHY Empis? Because after 2 weeks of unreturned calls to Weber direct we got fed up and called an Alfa supplier and he recommended the EMPIS. According to him they are as good as the Weber and is the same design. MY issue so far is the manifolds fit like SH*T I spent 30 minutes going from the car to the drill press reaming out ALL 4 holes to get the F-ers to fit.2 center holes had to be drilled out to 3/8" and the outer slots had to be drilled out to 3/8 AND lengthend. Was this a vision into the future (tommorrow) of how things will go when I start the car up ?
Once the manifolds were done everything else went fine. Is this a common issue and will the carbs end up being problematic? |
JPB |
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 ![]() |
Hehehe!
Sounds like he might have a mid range cam in that thing. Ask him what he's got before you rack your head wondering why the thing won't pull past 3.5K (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 24th June 2024 - 07:15 AM |
