jr91472 |
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 ![]() |
I have a recurring problem with the float in my sender getting stuck at the 1/4 guage level. I have read all the articles about cleaning the sender and have removed and disassembled this one many many times. But I can't find anything visually wrong with it.
Yet once I get the float "unstuck" it works fine all the way till the tank is empty. But when I fill the tank up, the float gets stuck again. On the bright side; as I use up the gas and the level comes down, the float gets "unstuck" and provides accurate readings from 1/4 to empty (even the reserve light works), but will never go all the way to the top when the tank is full (unless I pull the sender apart again). The wires look clean and straight. When apart, the sender provides good readings on the voltmeter (~75-5 ohms). 1st Question: Any secrets or clues on how to clean that I am missing? 2nd Question: Can the sender be used without the metal tube? I am asking cause I am thinking that perhaps the float is getting wedged against the tube (somehow). I assume that the purpose of the tube is to fill up with gas and provide some buffer against fuel slosh (thus providing more consistant reading while driving). Any thoughts before I toss this one and buy a (peresh the thought) NEW sender? thanks all (IMG:style_emoticons/default/beer.gif) |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Without the cylinder the sloshing fuel will cause the float to jump up and down causing the needle to do the same. The hang-up is 2 things: the wires could be rough or kinked. Use emery cloth and gently clean the pick-up wires. The other thing is the center post. It must be clean and smooth. The float rubs on the center post as it goes up and down and can get stuck on the smallest of burrs. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:00 PM |
