Recommended Rev limit for 2.7L 6 cyl, I'm curious |
nine14cats |
Dec 23 2003, 10:53 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
Anyone know what the factory valve train is good for at the upper rev limit in terms of reliability? I've got a pumped 2.7L in my 914 with carbs and 10.5:1 compression, mod heads, big cam...the works. Last year I ran without a rev limiter (i'm a knucklehead) and used 7500 rpm as my limit. Towards the end of the year I over-reved the car with my right foot to ~8K a few times and broke a few rings. I had the engine dis-assembled and it's all prettied up again (including more mods!), but I was curous as to what the motor's hardware was originally designed to do. I've heard alot of folks recommend 7200 rpm as safe and reliable.
I purchased a new MSD ignition with the adjustable modules. I can program the rev limit in 200 rpm increments. I'll start at 7K for awhile. Anyone know what the design limit is? The car has stock valves, springs, crank. Heads have been chamfered for clearance and the pistons are JE. Camshaft from webcam. Weber triple throats on each side. The motor will rev easily to 8K with the tap of the foot. Thanks in advance for the opinions! (IMG:style_emoticons/default/wavey.gif) Bill P. |
drew365 |
Dec 24 2003, 10:03 PM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
QUOTE for power, more than 500 rpm over peak power doesn't seem to buy you much... I assume your talking about peak horsepower? My car dyno'd with hp peaking at 196.5 @ 6900rpm. So using 7400 to 7500 for the limiter falls right in there. I found that on the track I usually run, if I lower the limit I get caught having to shift where I don't want to. |
Lo-Fi Version | Time is now: 31st October 2024 - 07:23 PM |
